like it says but not the amount of travel before the brake grabs but the up/down movement. when I'm riding side streets at low speeds it just rattles big time and drives me nuts.
any input would be great. thanks
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
99 fatboy chromed to he77 and back.
-Respect the person who has seen the dark side of motorcycling and Lived, and still rides.
Does your model have the anti-rattle clips? If not that may help.
__________________
2005 Anniversary Edition Fatboy 95" with 104 hp & 102 ft lbs tq, 211 SE Cam, Power Commander, T-Man Stage II Heads, Vance & Hines Big Radius 2 into 2 pipes, Performance Machine Hooligan wheels and mathching air cleaner, assorted list of mods...and always ongoing!
brake cable seems ok. at least the amount of pull to engage the front brake is good. how do I add washers or check that ones thats in their? is the bushing thats in their at the top of the pin? how do I pull the pin to check it out.
any more details on how to do this would be great.
thanks a lot for your guys help
__________________
Under the bottom side of the pin there should be a "C" clip pull the "C" clip and remove the pin. There should be a plactic bushing in there where the pin goes. See if it's worn or cracked. "Cable"???
__________________
2000 Fatboy
95" Big Bore
Head work by Short Block Charlie's
S&S 510G cams
V&H ProPipe HS
