i remember reading that service bulletin awhile back and from what i recall it did not mention fl models. I searched for it again and found this. No mention of tq specs but certainly is addressing the clunk issue and no mention of fl models. Some one smarter than me needs to find the actual bulletin that mentions fl models and 70 lb's of tq and post for us.
**Thanks Kuma! I looked for my cc of the service bulletin m-1215 but could not find it. However, my previous comments were taken specifically from the instruction sheet #j04469 that came with the kit as mentioned in the bulletin. I didn't write the instructions...only relayed what I read. By the way, those instructions do not mention the FL models as someone suggested. MY BAD!!
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
WOODY
06 STANDARD CHROMED TO THE MAX
LIFE IS NOTHING BUT A LONG RIDE...IF YOU ARE LUCKY. I AM !!
And yes, you get a little grease seepage, BFD. It cleans off.
I would much rather wipe a little grease once in a while than die because my bearings are shot and the steering fails.
But I RIDE mine, it gets dirty, and sometimes it don't get cleaned for a while.
If you're riding with a shimmy or shake on decel, your bearings are loose, and dangerous. adjust them up. As I mentioned previous, 120 in-lbs should do it, if not, I would go as far as 144 in-lbs... That's 10-12 ft-lbs for those of you that are mathematically challenged. DO NOT use a big tq wrench for this task, you should not use the bottom 20% of the range on your wrench, they are not designed to be used that low, and are not accurate. Buy a smaller tq wrench, so that you are in the middle of the range.
If you are riding and at speed find yourself having to make steering adjustments, chances are you're bearings are too tight. a 2 wheeler should run straight down the road with no help, if everything is adjusted correctly.
Be safe, Y'all!
Thank U safety man.
I was a machine repairman for 38 yrs and I'll put my experience up against bout anyone..
I have installed, rebuild, overhauled; pillow block, flange, cup, roller, type units that have ball, needle, roller, tapered, and thrust type bearings in machines, transfers . differentials, gears reducers, gear boxes, CV joints, universal joints EYTC> ETC> in doing my job..
So I am not a green horn in the care and lubrication of bearings...
Hey oct1949. Have you used "LUCAS RED STICKY #2". Been using it about a year in my steering head and so far it has stayed in place. On rare occasion i'll get a tad oozing out but one swipe with a paper towel cleans it up pronto. Never a blow-back.
__________________
WOODY
