[quote=albertgiancarli;5666323]I have an 04 Fat Boy.
I saw an earlier post that the MOCO issued a service bulletin in 05-06(?) that indicated a higher torque value than that previously published for the stearing head bolt. I was a bit confused as I didn't think this adjustment was about applying specific torque to this bolt but rather having the correct Fall away.
I gotta admit I think the Fall away adjustment technique is low tech. Does HD now recommend a torque value instead of doing the Fall away??
**NO! NO! DO BOTH!!
...there's too much subjectivity to the Fall away method.
**RIGHT YOU ARE!!
**OKAY...I PREVIOUSLY POSTED INFO ABOUT THE MAINTENANCE BULLETIN #1215 ADDRESSING FRONT END CLUNK. COVERED 2006 AND EARLIER SOFTAILS AND SOME DYNA. IT STATES, IN PART, THE STEERING HEAD BOLT SHOULD BE TORQUED 70-80 FOOT POUNDS...THEN ADJUST FALL AWAY BY THE BOOK. BY THE WAY, THERE IS A HEAVY DUTY FLAT WASHER AVAILABLE AT HD TO REPLACE THE STOCK FLIMSY ONE. OTHERWISE YOU CAN'T TORQUE IT AS HIGH. TORQUEING BEFORE FALL AWAY DOESN'T MAKE SENSE BUT...IT DOES WORK. AT LEAST IT DID FOR ME. I CAN'T IMAGINE LATER MODELS NOT HAVING SIMILAR TORQUE VALUES AND PROCEDURES. GOOD LUCK!!!
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
WOODY
06 STANDARD CHROMED TO THE MAX
LIFE IS NOTHING BUT A LONG RIDE...IF YOU ARE LUCKY. I AM !!
**NO! NO! DO BOTH!!
**RIGHT YOU ARE!!
My 03 manual says to tighten fork stem bolt until bearings have no noticeable shake. DO NOT OVERTIGHTEN then adjust the fall away. Must be why I have to hold on to the bars with both hands on decel
__________________ there are two types of boats, Submarines & Targets! SSBN 619
Big Sucker jetted and SE II's with Thunder Monsters!
Member of Patriot Guard Riders. #164014
**THE STEERING HEAD BOLT SHOULD BE TORQUED 70-80 FOOT POUNDS...THEN ADJUST FALL AWAY BY THE BOOK.
Are you crazy! Your fall away would be ZERO!
On another response some guy said he pumped in 130 squeezes on the grease gun. He will now have 130 squeezes of grease blowing back on his motor on the first hot day. Don't overtighten and don't over grease! A pump or two is fine...sheesh.
If the neck has been serviced and is full of grease I agree with U,
BUT, That 130 pumps maybe a 1/2 cup is what it took to get ANY grease to come out of the bearings. there is not a big blob of excess grease waiting to fall off..
In order to get grease into the races U have to use enough to fill the neck full so the grease can be forced through the bearing races and the only way to know that has happened is when a little comes out of the bearings.
The manual even says to do that.
If the neck is void or not full of grease and U only use a pump or two, then U'll never get grease to the bearing ..because U'll never fill the neck to put pressure against the bearings.
My point was I am not sure the Wrenches have been greasing it or if it was ever greased when it was in for the services..because it took so much.
I'm not sure, but I think that they are talking about torquing the stem bolt down then loosening and adjusting the fall away. I had to do this to mine. I adjusted mine three times in 1500 miles. I would adjust it and ride and it would be loose again in a couple hundred miles. The last time I did it I cranked it down fairly tight (maybe 30-40 ft lbs) then loosened and set my fall away. 2000 miles on the last adjustment and still just right. As far as filling the neck with grease, I don't know about that. Seems like it might seep out the bottom until the end of time.
on past post if its done correct others also say it will seep a little for a few miles.
Mine did it only when new. thats why I am not sure its been greased since she was new by the dealers wrenches at service time.
I get the same shake, I know the bearings are loose but I just haven't taken the time to fix it.
Quote:
No joke! On the Fat Bot front end I have that would be a death ride. That is correct for the Dyna's where there is an adjusting nut for the bearing pre-load under the top tree. You adjust the pre-load then you torque the nut that holds the top tree to the 70-80 lbs.
__________________
First annual N/W hook-up was a BLAST!!!! Newly posted pics.......look here.......
You are absolutely 100% correct.
And yes, you get a little grease seepage, BFD. It cleans off.
I would much rather wipe a little grease once in a while than die because my bearings are shot and the steering fails.
But I RIDE mine, it gets dirty, and sometimes it don't get cleaned for a while.
If you're riding with a shimmy or shake on decel, your bearings are loose, and dangerous. adjust them up. As I mentioned previous, 120 in-lbs should do it, if not, I would go as far as 144 in-lbs... That's 10-12 ft-lbs for those of you that are mathematically challenged. DO NOT use a big tq wrench for this task, you should not use the bottom 20% of the range on your wrench, they are not designed to be used that low, and are not accurate. Buy a smaller tq wrench, so that you are in the middle of the range.
If you are riding and at speed find yourself having to make steering adjustments, chances are you're bearings are too tight. a 2 wheeler should run straight down the road with no help, if everything is adjusted correctly.
Be safe, Y'all!
__________________
Hi, my name is Chip, and I'm a poser...
I remember reading that service bulletin awhile back and from what I recall it did not mention FL models. I searched for it again and found this. No mention of tq specs but certainly is addressing the clunk issue and no mention of FL models. Some one smarter than me needs to find the actual bulletin that mentions FL models and 70 lb's of tq and post for us.
