Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Softail Models
Sponsored by: Cajun Shine All
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-02-2009, 09:36 AM
mke125125 mke125125 is offline
Prospect
like I said. you dont HAVE to do anything
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
mke125125
Old 10-02-2009, 11:38 AM
JonnyD's Avatar
JonnyD JonnyD is offline
2009 Toyota FJ Cruiser
My Garage
The download won't do anything for the heat issues with these motors, it's still EPA compliant and the dealers hands are tied on that.
Before you go out and do the swap, spray some kroil or other loosening agent on the muffler clamp area if you prefer. I didn't and they come off with a little
coaxing and wiggling side to side up and down.
Some say not to use any sealant, but it's cheap ins, and will assure no leaks. I used permatex ultra copper high temp, and applied a thin Bead to the header and slid the muffler on. Gave it a slight twist to spread it evenly and tightened it up. Any leaks in that area can cause decel popping and also discoloring.
As for your worry about the download, etc. For a little more money you can get a FuelPak or PC and very easily tune your bike for a stage 1, while also richening it up a bit to cool the motor temps.
Good luck and don't hesitate asking, these have been asked by many and that's why this forum is so nice!
Old 10-02-2009, 08:21 PM
Gman in NC's Avatar
Gman in NC Gman in NC is offline
Hang Around
Default OK Hogowner69
Put my new Rush mufflers on today. It was about a four beer job. They look and sound great. I have the 1 3/4" baffels and I think they will be great. Will ride it in the morning. The four beers held me back for today.
changing-only-mufflers-do-you-need-fuel-management-or-high-flow-filter-pipes-oct-2-2009-004.jpg
Old 10-02-2009, 09:38 PM
oct1949's Avatar
oct1949 oct1949 is offline
Quote:
Originally Posted by JonnyD View Post
The general rule is this: More air in & more air out=tuning needed
Mufflers only=no
Mufflers are very easy to swap. "They" recommend new clamps, but I've used mine on 2 different swaps and they work fine. I also use copper high heat silicone sealer to stop any leaking, which leads to decel pop and possible discoloration at the joint.
Good sounding is all relative, I prefer Vance and Hines and BUB. Quiet baffles with any muffler give a nice low growl at idle but allow bark on accel.
How Ya liking that new Heritage. I myself am giving a slight consideration to jumping back on a Softy. It's a big maybe, but stranger things have happened.
Just the same as above.. I did have to have new clamps as the dealer couldn't get my sealed and they don't use the copper sealant, but I think it would probably work, let it dry and set before starting if U do,
I like the sound of My Rush. 2'' but they won't give U the gain of a 2-1 system.
I was satisfied with having a little less in power just to keep the sound of them..
__________________
RIDE DEFENSIVELY.
07 FLSTC/ Andrews 26H cams, 24k miles
SERT, Rush 2"
SAE 80HP/92TQ
STD 85HP/98TQ
Old 10-03-2009, 12:07 AM
av8or av8or is offline
Prospect
Rush performance says 1.75" is as large as you should go without an air/fuel tune of some kind. Thats what I put on my 09 fatboy and it runs great without any other changes. In my opinion it sounds great. That is a beautiful bike you bought (best colors in a long time). Good luck, and let us know how you like them.
__________________
Old 10-03-2009, 08:48 AM
PirateRider's Avatar
PirateRider PirateRider is offline
Hang Around
You can look into the Xieds per my earlier post. This will change the A/F ratio like the HD remap. I was pleased but at some time will most likely go SERT or PCV and a Dyno. Much later actually...
__________________
Pirate Rider
2009 Softail Deluxe
Old 10-03-2009, 08:55 PM
Gman in NC's Avatar
Hang Around
Default Hogowner69
Put about 100 miles on my bike today with the new pipes. I got the 1 3/4" baffles. Couldn't be happier. My friends say it's the best sounding pipes they've heard. They look great. No issues with performance. No popping, dead spots or anything. I'm going to monitor the gas milage for awhile to see if it is changing. If it increases a lot that means I'm running too lean. Don't see that happening though.
Old 10-03-2009, 11:29 PM
oct1949's Avatar
Quote:
Originally Posted by hogowner69 View Post
thanks guys....but one question...the number size of the baffles...what do the numbers stand for..in other words...what is the difference lets say between the 1.75 one and the 2.25 ones..
thanks
that is the size of the hole through the inside of the baffle..
3 yrs ago the 2'' was prob the most sold, and what I have, at 60 I wouldn't want bigger, and they would not have any back pressure... lots of rider now are going wiht 1 3/4'' a little less sound and not a deep. maybe a little more tq, can't say, never seen a dyno on them..
I have stayed with mine since the 1k and now with 24k we still really like them..
The cams this spring really made them even deeper and they hit harder when U crank on it..
__________________
RIDE DEFENSIVELY.
SERT, Rush 2"
SAE 80HP/92TQ
STD 85HP/98TQ
Tags
2007, 2010, add, changing, download, fatboy, filter, flow, fuel, harley, hd, high, management, muffler, pipes, slip, softail
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
