Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Softail Models
Sponsored by: Cajun Shine All
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 09-15-2009, 04:19 PM
redbone62's Avatar
redbone62 redbone62 is offline
Prospect
ya i just had a fuel pump replaced a month ago and think thay replaced everything in the tank including the quick conect and hose to it
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 09-15-2009, 04:35 PM
wctom wctom is offline
Prospect
I replaced my CPS on my King a couple of months ago. The bike would start right up in the morning, but once it got hot, it would start backfiring as I slowed down. It also ran a little rough. I had no clue what the problem was, then we stopped at a gas station one day after riding most of the day. Couldn't get the bike started until it cooled down. Then as the bike heated up again, running rough and backfiring. A little time on Google and I decided to spend the $57 and change out the CPS. That was it, all fixed. Well, at least until the VSS went out about a month ago. All in all, the same type of sensor. I understand that these sensors have a history of going bad.
__________________
1999 Mystic Green Road King Classic
Stage 1
Old 09-15-2009, 07:53 PM
rbabos rbabos is offline
A crank sensor should emit a voltage pulse across the leads when the engine is rotated. Anybody know what it is on the Harley CPS. Others I've read about are in the 2-5 volt range.
Ron
__________________
07 Softail Custom
V&H BSS
Screaming Eagle Heavy Breather
Screaming Eagle Big Twin Compensator
Tmax
Harley Blade 41681-07 wheel
The puppy lasted until fall. Now in teardown mode for new build
Old 09-16-2009, 06:12 PM
man4mopar's Avatar
man4mopar man4mopar is offline
Quote:
Ron
According to my dyna manual they require a minimum 1 volt AC while cranking. Also lists a ohm range of 600-1200 if fails either first check for loose fit of sensor, last make sure end is clean of debri. If it failed to produce 1vac and or ohm out of the 600-1200 range is tightly installed with a clean end to replace the sensor. I would bet the B motor in the softies are the same spec but may not be.
__________________
2006 Wide Glide
American suspension's Dragon Springer
Fabricated to fit softail rear bobtail fender
06 Night Train dish wheel with 200mm tire
And some other stuff
Old 09-16-2009, 09:08 PM
redbone62's Avatar
Prospect
Angry
yep just spent 88 bucks on cps and system relay and starter relay the good news i now have all three spare parts due to that dident solve i fricken problem still square one i think fuel pump or regulator not getting enough pressure to injectors and all this is new 88 miles ago im pisted off anyone ever get a pert from harley and afeter a month or so go bad? are thay fair and take care of it or just say screw you ??? i dident have them do the work my buddy has a cycle shop he did the work i bought the parts?
Old 09-16-2009, 09:50 PM
jimmers1817 jimmers1817 is offline
Quote:
What made you think it was the cps anyway?. Didn't seem to fit since you had spark.
__________________
2008 Heritage Classic
Old 09-16-2009, 10:10 PM
redbone62's Avatar
Prospect
i hear of them going out and still having spark
Old 09-17-2009, 04:14 AM
texas_speed_freak's Avatar
texas_speed_freak texas_speed_freak is offline
Prospect
+1 on that. the cps tells it when to spark. it can be sparking and still not fire if it is reading incorrectly and sparking at the wrong time. thats why it will be very hard to start or start and not run correctly once started. also pick up metal and not work correctly
__________________
You cant know where your going until you know where you've been
Tags
2000, ckp, crank, davidson, fails, harley, king, motorcycle, position, road, roadking, sensor, softail, symptom, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
