I need some advice and hope I find someone that has done this project.
I am in love with 2 bikes, the Nightrain and the Fat Boy. I love the train’s looks but like the Fat Boys front end better.
After trying many different things, most recent being the 120/70/21, I am still not happy with the front end looks.
This winter I would like to replace the entire front with a Fat Boy set up. On page 114 of American Iron Mag is the look I am going for.
I have a 2006 Train and am looking at the 2007 Fat Boy front since that was the first year of the 17” wheel. Both front and rear should be 17’s then.
According to http://www.totalmotorcycle.com/photo...NightTrain.htm
I have a 1.5 degree fork rake in addition to the 32 head, where the Fat Boy has only the 32 head rake.
My main concern is spending all this money to find I am not balanced right or run into handling problems.
I would not mind lowering the rear .5 to .75 if it came to it.
Does anyone know of this front swap being done or have any good advice on it?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
I have similiar feelings about the Night Train's front end. But I think I will be going to a Wide-Glide front end and sticking with the "standard" looking forks. The WG forks are 49mm instead of the Night Train's 41mm. Good Luck with your swap and post pics along the way.
__________________
Peace and Grease
I havent done that exact setup but did change out my front end... Most front ends are interchangeable, having said that its the details that you must be concerned with.. i.e what size wheel is it the same axle size, hub size will the original caliper fit or need to change that out...
Rake and trail factors, but i really dont pay attention to the numbers if it handles well..
Shaved Ice has a point, maybe go from a 41MM to 49mm, it would make a big difference.... I have one for sale... : )
Not sure about the newer bikes...but here is a 98 FXSTS with a Fatboy frontend...
Twas done when I got it but looking at the setup it looks as easy as taking off the bars and top of the triple tree...sliding the front end out. dropping in a new one and your done. You'll have to setup the neck bearings etc...but really no big deal.
first of all wv, you ever look into just buying the nacell cover and soup cans for your current front end thus giving you the fatty front end,,,,, second shaved ice, you have a wg front end, the mid glides have the 49 mm front end......unless the 2010s are diff
I may have my models mixed up. Let me try to explain the look I am going for: The Dyna Fatbob front end has 49mm forks. The Night Train has 41mm forks. I want to put the 49mm Fatbob forks and triple trees on my Night Train for performance and looks purposes.
__________________
Peace and Grease
I have had the same idea, but not sure of the details. Everyone says it is a simple swap. In the mean time, I have opted to swap in a smaller diameter fatter tire on the front end of my 2003 Deuce. Next I need to fit a smaller and wider fender. Not sure if I will stay with this or go for the full front end swap. I posted a few pics to my garage.
