It's gavity... So cracking the bleeder like a car don't work... make sure everything is tight and fill the master leave the cap of and put rags around so fuild don't get on everything... Take your time and pump gently and slowly don't rush... you'll see tiny air bubbles coming up... slow and smooth... then when you begin to feel slight pressure put a rag over the top of the master and give it some quick full speedy pumps the reason for the rag is when the air is gone and the pressure builds it'll shoot fuild up so the rag will get soked but it won't fly all over the place... it works for me and leaving it over night is a good way to start it off. Good luck
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
go to walmart buy a meat marinade injection syringe, then go over to the pet department get some clear tubing in the fish tank section. Install the tubing on the end of the syringe. You might have to use a cig lighter to heat up the tubing so it will fit. Remove MC cover plate. And slowly inject the new brake fluid into the brake caliper pushing air and new fluid upwards into MC. Bleed accordingly. The whole setup should cost less than 10 bucks. Hope this helps
man im out the door walmart hear i come thanks sportyguy
no problem that is what I used to bleed the front brake of my fatty when I put on the apes. I tryed the leaving the front caliper bleeder open over night, didnt work for me. Used the setup from Walmart and bleed the brake in less than 10 minutes.
+ 1 what Sportguy said. If you have access to a vet or medical supplies a 50 ml syringe will work great. go to www.fatbillscustoms.com for step by step instruction.
I have read this site and the overnight blled method.. My question is do you clamp the lever with the res open or screwed down tight? on front brakes?
__________________
good evening. do you know how fast you were going?
2007 Black Pearl Ultra
Kuryakyn Pipes, PCV, K&N SE Stage 1 kit,H-D Premium Oil Cooler
RJS Originals, HD Oil temp gauge and front fender LED light trim,Blindspot fairing mirrors Behind every bouncing ball is a running Child
i had the same issue and found out i over filled the system. i used shop towel to remove some and it worked great. also i had to clean the pistons. this is very important. http://www.lyndallracingbrakes.com/service_tech.htm
__________________
2007 Fatboy
Hooker Rebel, Arlen Ness Big Sucker, Mustang seat, RearAlert
Thundermax with autotune, Dunlop RoadSmart 200/50 rear Avon Storm front 130/70 http://gallery.me.com/tk353
found my new best friend today at walmart and its a good garage weapon also look at the tip on dat bioch come talk smack in my garage might get a neck full of dot 5 ha ha ha
all i can say is every ones got there ideas how to do the brake i spent 349 for flavor injector at walmart dident have the correct hose i needed there so i wondered next door to lowes found what i needed and seen my favorite mid fortys casher that love harleys ya dont worry shes on the list of things to do got home and in shit you not 7 min i had a rock hard brake lever so thank you to the guys that helped out with where to find my syringe at
Hey Redbone thats a nice setup you got there. Kinda looks just like mine....lol. Mine worked just as good. Have you been hangin out in my garage???...lol
