Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Softail Models
Sponsored by: Cajun Shine All
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 08-28-2009, 10:59 AM
entourage entourage is offline
Hang Around
Default Internal Wiring Handlebars
alright, i know there's a bunch of threads on this, but they are very sporadic. i'm installing carlini t bars on my rocker (9 inch). have tank off and all the wiring disconnected, but i can't get them ran through the bars. can you guys share what has worked/not worked as far as getting wires pulled through your bars? any brainstorming ideas would be appreciated. this has already turned into a three night project!
Thanks!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 08-28-2009, 11:10 AM
Reino_79 Reino_79 is online now
Prospect
I havent done this yet but try a coat hanger with string to pull them through. If that doesnt work maybe just try and feed a string through and tie the string to the wires and pull them on through.
__________________
'06 Deluxe
http://farm4.static.flickr.com/3607/3647271921_424049217b.jpg
95" Stage III - 89 H.P. and 106 TQ.
Samson True Duals w/33" fishtails.
Old 08-28-2009, 11:12 AM
Buellrunner's Avatar
Buellrunner Buellrunner is offline
Hang Around
when I put my WO508 chubbys on last month, we just pushed the wires through and grabbed them when they came close enough to the opening....
Have you considered zip typing them together to cause additional rigidity and then pushing them through?
Also, make sure your wires are long enough - I wasnt happy with the strech and decided to extend each individual electrical wire Took some time, but with a little patience came out great!
Cheers!
Old 08-28-2009, 11:25 AM
Hang Around
thanks for the replies guys. from everything i've read on this site the standard wires are long enough for the 9 inch bars.
what i've tryed so far is pulling a fairly flexable wire through and rapping it around the wires to get it through. when it gets to the "t" i think it's getting caught and the wire i have rapped around pulls off (i was pulling HARD with frustration).
i've read baby powder may help?
has anyone tried pulling the wire housing hose off and doing it individually?
Old 08-28-2009, 03:46 PM
BigMike17's Avatar
BigMike17 BigMike17 is offline
Senior Rider
Try a heavy duty string with a bolt on the end to give it some weight. Send the string through, can use a vacuums suction to pull it through. Then, you can tape the wires, securely, to the other end and get 'em pulled. Good luck -
__________________
Rom 1:16 - Not Ashamed
'06 Fatboy, DuPont Hot Rod Black, Gloss Black Ol' School Striping
20" Apes on 4" Riser, Front end powdercoated/Chrome accents
V&H Short Shots Staggered Black, RK Hard Bags, Heritage front fender
Custom laced seat from Butch Watson, High Rollers Cycle Seats
Old 08-28-2009, 05:42 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe BLKnCHRME09Deluxe is offline
tied a shoe string to the wires and used a vacuum to pull the string through. Once i had ahold of the shoe string i pulled and what do ya know, wires!
__________________
2009 " BLKnCHRME09Deluxe " Deluxe
Samson longtails - PowerCommander V
HD heavy breather - Burly Brand up top
21" DNA front - lowered front(Progressive) & rear(Shotgun air ride) - Chrome
Old 08-28-2009, 07:04 PM
priceamp's Avatar
priceamp priceamp is offline
Senior Rider
Quote:
Like you, I used a long piece of 18g stranded wire wrapped around the end of the wiring harness and pulled the harness through the bars. However, I also wrapped black electrical tape around the lead wire and the harness to give the wrap more strength. However, I can see if you need to take a sharp turn the lead wire may pull a part from the wire harness.
When you say “housing hose”, do you mean the existing stock conduit used to cover the individual wires? If yes, I guess it would be ok to run them one at a time. Just be sure that once you get all the wires through that you use conduit or shrink wrap tubing over the wires where they enter and exit the bars. And of course use shrink wrap tubing where you have spliced wires.
__________________
06 FXSTi
Custer State Park, Sturgis Bike Week 2009
Old 08-28-2009, 08:45 PM
RHillbilly RHillbilly is offline
Prospect
I had to pull the coating off and do mine 2 at a time used masonery string make it long enough to get them all thru with one peice also rap tape around them after you tie string on them I used dishwashing soap they slid rite thru,after I got them thru put a peice of heat shrink where they go into and out of bars
Old 08-28-2009, 09:17 PM
Soul_Cal's Avatar
Soul_Cal Soul_Cal is offline
Prospect
1981 Yamaha SR500
Thanks!
I used a shoe string (tied and taped with electrical tape) and sprayed a lot of Silcone Lubricant. Push the wires from one-side and pull from the other side using the shoe string.
When you get to the T section, the wires will start to bundle up. You need to pull it back (reverse) then push the wires and pull with the string again. The back and forth action will get you through the T section. You will need to pull it back and forth several times in small increments. Constantly add silicone lubricant and be patient. The key is going back and forth in small increments to avoid the bundling of the wires at the T section. You can do it!
If you want to have some real fun, try internal wiring a set of Kodlin Apes ....
__________________
2003 Harley Davidson Night Train
Old 08-29-2009, 02:40 AM
grumpez grumpez is offline
Hang Around
Quote:
This is what I did when I installed my bars, worked great.
Tags
07, bars, haley, handle, handlebar, handlebars, harley, internal, motorcycle, night, pull, softail, train, wire, wires, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
