Motorcycle Lift - Pep Boys is this any good?
Is this lift any good for my Fatboy? I only plan on using it for cleanings and basic serviceing. \\;
Torin™ 1500 lb. Motorcycle Jack
[/align]
[/align] [/align]
$59.98[/align] each after mail-in rebate[/align] (Reg. $79.99)[/align]thru Jun \\;28 DrawShoppingListLink("-2091442753", "/pepboys/default.aspx?action=addshoppinglist&storeid=231506 9&pretailerid=&listingid=-2091442753&offerid=0&catid=&redirect=%2fpepboys%2f default.aspx%3faction%3ddetail%26flashbrowse%3dy%2 6storeid%3d2315069%26rapid%3d556135%26pagenumber%3 d6%26listingid%3d-2091442753%26shoppinglist%3dy&ref=%2fpepboys%2fdef ault.aspx%3faction%3dbrowsepageflash%26storeid%3d2 315069%26pagenumber%3d6%26rapid%3d556135%26prvid%3 dPepBoys-080622&finalprice=59.9800", "+[/align]Add to Shopping List[/align]", "-[/align]Remove from List[/align]",","cursor:hand")
[/align] [/align] Folds for storage.
6 locking positions
locking swivel casters
Handle included.
$69.98 promo price - $10.00 mail-in rebate = $59.98 each after mail-in rebate[/align] #T64017[/align] [/align] [/align]
[/align]
[/align] [/align]
6 locking positions
Handle included.
RE: Motorcycle Lift - Pep Boys is this any good?
It's certainly not as good as mine:
http://www.jsjacks.com/videos.htm
But for that price it will probably suit you fine. \\; Just make sure you have the ground clearance to fit the jack under your fat boy. \\; And you may have to strap the bike for stability (don't need straps with mine). \\; \\; Some say you should put pads under the rails where your shocks are so they don't rest on the jack but J&\\;S states you don't need them. \\; \\; I use them anyway.
FYI, \\; the Sears yellow jack is very popular here on the forum also. \\; I think it runs around the same price, \\; maybe a few bucks more. \\; Actually you'll probably fine most of those bargain jacks are made by the same company.
ORIGINAL: KumaRide
Is this lift any good for my Fatboy? I only plan on using it for cleanings and basic serviceing. \\;\\\\\\;
[/align]
[/align] [/align]
$59.98[/align] each after mail-in rebate[/align] (Reg. $79.99)[/align]thru Jun \\;\\\\\\;28 DrawShoppingListLink("-2091442753", "/pepboys/default.aspx?action=addshoppinglist&\\;storeid= 2315069&\\;pretailerid=&\\;listingid=-2091442753&\\;offerid=0&\\;catid=&\\;redi rect=%2fpepboys%2fdefault.aspx%3faction%3ddetail%2 6flashbrowse%3dy%26storeid%3d2315069%26rapid%3d556 135%26pagenumber%3d6%26listingid%3d-2091442753%26shoppinglist%3dy&\\;ref=%2fpepboys %2fdefault.aspx%3faction%3dbrowsepageflash%26store id%3d2315069%26pagenumber%3d6%26rapid%3d556135%26p rvid%3dPepBoys-080622&\\;finalprice=59.9800", "+[/align]Add to Shopping List[/align]", "-[/align]Remove from List[/align]",","cursor:hand")
6 locking positions
Handle included.
[/align]
[/align] [/align]
6 locking positions
Handle included.
 \\;I bought mine at Harborfreight.com for $59.00 \\; It looks just like that except yellow. The only problem I have is it is hard to control the Down speed (very fast) \\;even with the adjuster valve closed all the way.
I have a pepboys jack and it works fine on an 06 fatboy. I dont use it often, therefore, I dont really need a better one. clearance, on an 06 fatboy, stock height, it works fine. I have mats on my floor so i have to stand the bike more upright to clear the low side of the frame. I just twist the bar the oppisite direction and kind pull on the bars as it slides under. by the way I got it a last summer on sale with the coupon and sale price it was only 39.99.
ORIGINAL: KumaRide
That jsjack looks very good.
The Sears yellow is on sale for $180. Sears has a red one, probably very similar to the Pep Boys lift, for $120. I have read that the red one sometimes goes on sale for ~$80.
ORIGINAL: jimmers1817
Wow, \\;\\\\\\;\\\\\\\\\\\\\\; I thought the yellow one was around $79. \\;\\\\\\;\\\\\\\\\\\\\\; I was way off.
ORIGINAL: KumaRide
No, you were correct. The yellow one is around $80.00. I don't know where those other prices came from.
EDIT: I just checked Sears.com. Looks like they "jacked" up the prices big time.
I bought the Sears one for around $100.00 about 4 years ago for my Ultra. It holds the Ultra nicely as with any big \\;dresser.
The Sears one also has hold down points to strap the vehicle to the lift so it doesn't fall off.
Be sure the bottle jack will hold the required weight.
Ron
Ron
The Sears yellow I found is $180 - \\; is another one that I didt find and should consider?
http://www.sears.com/shc/s/p_10153_1...Lift+Equipment
