Seat Bolt
Old 04-17-2016 | 01:21 PM
atomicair's Avatar
atomicair
Default Seat Bolt
Can someone tell me if your local Harley dealer carries these bolts for our seats. I called and the guy doesn't know what I'm talking about. Can I order them from someplace else? Thanks
Old 04-17-2016 | 04:34 PM
uklauren's Avatar
uklauren
Florida Crew Moderator
They must have a bunch in the service department - my friend got her Slim back without the bolt put back on after the bike was serviced.
Old 04-17-2016 | 06:02 PM
SLV's Avatar
SLV
It's a 1/4-20 threaded screw. A 3/4" or 1" length will do. You can find it at any hardware store.
Old 04-17-2016 | 06:18 PM
S.D.M.F's Avatar
S.D.M.F
It might be :#52720-00A.
Post a pic of where it goes and i can tell you.
Old 04-17-2016 | 06:37 PM
atomicair's Avatar
atomicair
You bolt it on the frame and if you want the solo seat you use the threaded hole to screw the seat on. I hope it makes sense.
Old 04-17-2016 | 06:39 PM
Mikula's Avatar
Mikula
might try dennis kirk but it looks to me like any correct sized bolt will do unless i'm misinterpreting the pictures
Old 04-17-2016 | 06:44 PM
atomicair's Avatar
atomicair
It's threaded inside the hole so you can use the smaller screw on the solo seat.
Old 04-17-2016 | 07:04 PM
Mikula's Avatar
Mikula
ah that makes more sense. you're basically looking for some kind of internally threaded banjo bolt
Old 04-17-2016 | 07:08 PM
Mikula's Avatar
Mikula
if you know the thread pitch it seems you're looking for something like this?
http://www.panicy.com/37-1016-riser-...er-front-ends/
atomicair (04-17-2016)
Old 04-17-2016 | 07:41 PM
S.D.M.F's Avatar
S.D.M.F
This is it: Part # 52720-00A
part # 6409 is the nylon washer if you need it.
Quick Reply: Seat Bolt
