chopped/bobbed rear fenders
Old 01-01-2016, 09:28 PM
tehan2's Avatar
tehan2
tehan2 is offline
Received 5,563 Likes on 1,246 Posts
Default chopped/bobbed rear fenders
looking for a winter project and decided to cut the the rear fender on my fatboy. Actually I'm going to pick up a cheap rear off ebay and cut that so I have my stock tins so I can switch back someday, but you get the idea.
so who's chopped their fenders? and please post a picture so I can be inspired and get ideas of the look I like
Thanks in advance
Old 01-01-2016, 10:23 PM
Just Enough's Avatar
Just Enough
Just Enough is offline
I bought a used Cross Bones fender off of eBay and cut it in the middle and shortened it 4 inches and lowered it 1 inch closer to the tire. The result is in the picture below.
Old 01-02-2016, 08:15 AM
FLS103's Avatar
FLS103
FLS103 is offline
I bought an old Fatboy fender, welded and relocated the strut holes, shaped the side radius and chopped both ends when I put the 200 mm on my Slim....
Old 01-02-2016, 10:16 AM
Jetfever's Avatar
Jetfever
Jetfever is offline
Default Front and rear
I found some fenders locally on Craigs, Saved my Stock fenders as well.
I cut @ 6-7" from the back of a stock Slim fender, mounted a Street Bob tail light with a doubler under the fender to avoid the cracking problem that HD had. The doubler is not visible unless you look under the fender.
The front was a Fatboy fender, but it is unrecognizable we cut so much out of it. You could use any HD fender that fits a softail when you chop a front.
Old 01-02-2016, 01:52 PM
stal94gt's Avatar
stal94gt
stal94gt is offline
It looks like it has aftermarket struts. What struts are they
Old 01-02-2016, 02:33 PM
Just Enough
OEM struts without covers.
Old 01-02-2016, 05:42 PM
tehan2's Avatar
tehan2
tehan2 is offline
what did you do to the edge? is it rolled or just ground smooth?
Old 01-03-2016, 06:38 AM
HrdNox's Avatar
HrdNox
HrdNox is offline
Nice!
Old 01-03-2016, 06:56 AM
Harliquin's Avatar
Harliquin
Harliquin is offline
That looks brilliant
Old 01-03-2016, 06:57 AM
Harliquin's Avatar
Harliquin
I love your exhausts!
Quick Reply: chopped/bobbed rear fenders
