S-Series - Home Base
#442
#443
Right Side Tool Box according to Harley does not fit the FLSS. WRONG, not in all cases, maybe they thought it would interfere with the shotgun exhaust. I don't know but I can tell you part number 64227-08 DOES fit. Problem is it only comes in evil chrome. I made one black and will mount it today. I don't have the OEM shotguns, if you do, you may try test fitting it as I did before purchase.
#445
With stock exhaust... that is correct. They will not fit out of the box. With aftermarket exhaust, it fits without issues.
I fitted mine with the stock exhaust, but had to make a few modifications to the mounting plate. But got it to fit with the stock exhaust. Here, take a look:
And link to the install: Right side toolbox install
(Got this from JP Cycles - Black teardrop toolbox Part No. 7010095 also needed bracket Part No. 7010086 and a few modifications to make it fit with stock exhaust)
#446
There are two different mounts for the box for softails, I tried the other one and the holes did not line up at the strut. The one I mentioned does line up. I'll take a pic of the bracket mounted and post it later, on the way to a funeral in 10 minutes. I figured it was the OEM shotgun that is the issue.
#447
#448
Link to the install: Right side toolbox install
Got the parts from JP Cycles - Black teardrop toolbox Part No. 7010095 also needed bracket Part No. 7010086 and a few modifications to make it fit with stock exhaust
I made a small bracket and also needed a small spacer (I will measure it when I get home since I have another one...)
Photos are in that link...
#449
Not sure who that was addressed to... but here is my install:
