Replacing front brake pads
Old May 15, 2008 | 08:02 PM
xltjim's Avatar
xltjim
Default Replacing front brake pads
Hi all, I am replacing the front brake pads on my 1977 sportster. The pads arrived with the rivets and the manual says to use a hollow rivet set to install them. Needless to say, I haven't got one of those and got the strange blank stare when I asked the service guy at the dealership about it. I could check with the local machine shop, but thought I would check with you guys if you have a way to attach the pads with the rivets, or a way to fabricate a tool which I would probably only use this time for this. I appreciate the help.
Regards,
Jim
Old May 15, 2008 | 08:15 PM
supr2nr's Avatar
supr2nr
Default RE: Replacing front brake pads
Here's what I did. Just went to autozone and picked up a set of flat tip punches. Used one to hold the rivet in place and then used another one and a hammer to punch the rivet and hold the pad. Worked like a charm. You will have to hit the hell out of the punch to bend the rivet and you will likely either need an extra set of hands to hold everything in place or use a vice.
Old May 15, 2008 | 09:59 PM
pyro's Avatar
pyro
You know, if you listen to Randy, you'll end up stuck on the side of the road.[sm=smiley2.gif]
https://www.hdforums.com/m_3364153/tm.htm
Rich
Old May 16, 2008 | 08:52 AM
supr2nr's Avatar
supr2nr
Yah but not because of the brakes.......errr...well at least not yet.
Old May 16, 2008 | 06:20 PM
xltjim's Avatar
xltjim
Thanks guys! I will give that a try (the punches not the breakdowns....at least I hope).
Old Jul 2, 2008 | 09:52 PM
xltjim's Avatar
xltjim
Hey I finally got to it and got it.&nbsp\\;&nbsp\\; I made a jig (of sorts) to back up behind the rivet.&nbsp\\; Just a screw through a 2x4 high enough to back up the rivet.&nbsp\\; I think I will call that harley tool no. 007.&nbsp\\; And a center punch to flare out the end of the rivet.&nbsp\\; Then a flat punch a little larger then the rivet to beat in into place.&nbsp\\; Looks good and tight.&nbsp\\; Fun working on these darn things although she tries to get the best of me at times.&nbsp\\; Thanks!!
JimmyL
Mar 5, 2018 05:43 PM
hdman6
Feb 29, 2012 12:04 AM
garand
Jan 1, 2012 12:13 AM
wheely
Apr 18, 2011 11:38 AM
drum412
Aug 8, 2009 01:22 PM
