panhead carb/cam
Old Apr 26, 2008 | 02:04 PM
smallmouth6810's Avatar
smallmouth6810
2nd Gear
Default panhead carb/cam
does anyone know if you can use a s/s super e carb on a 56 pan,with a sifton h can if they will work on it.
thanks james
Old Apr 26, 2008 | 09:05 PM
ruckster's Avatar
ruckster
Stage III
Default RE: panhead carb/cam
That's a big carb for a stock pan. The super B is a great carb for most pans, including the 88" S&S kits that make pans run incredible. I ran it for a long time with that setup and it would start first kick every time when warm, and 3d or 4th when cold. You have to get them set up correct, then forget them. Find someone to trade the E for a B and you will be a happy man on a happy pan.
Enjoy,
Sharon the Ruckster, staring at the new basket 50's pan. she should be done next summer....
Old May 9, 2008 | 02:30 PM
crampfan's Avatar
crampfan
I'm running a super "B" on my pan. But I have installed "E"s on pans and early shovels, they work just fine.
Old May 23, 2008 | 06:22 PM
stroker93's Avatar
stroker93
A SU carb will work on a pan just fine,,,,they are a constant velocity design and the motor vacuum decides how much fuel it needs. They also have an adjustible main jet.....it can be dialed from 74" to 88" with the same jetting, they can be replaced if you need to be richer or leaner.
Dave
Chuck U. Farley
May 6, 2016 10:06 AM
Smartbass
Jan 13, 2016 08:35 AM
french harley lover
Shovelhead
14
Apr 6, 2012 02:01 AM
JW1200
Apr 19, 2010 08:18 PM
shenork
Mar 22, 2009 09:01 AM
