Help - Timing on 1963 Flat head
Old Apr 24, 2008 | 11:26 AM
4rupert's Avatar
4rupert
Stage II
Default Help - Timing on 1963 Flat head
Greetings,
Newmember - long time HD owner.
Working on 1963 Flat head and not sure about timing. Here is my issue:
Timing mark on fly wheel which is a groove, does not line up
whenall of the cam gear marks are lined. Is this correct?
The engine runs but not very smooth. Help!
Jesse
Old Apr 25, 2008 | 06:46 AM
sqdealgeorge's Avatar
sqdealgeorge
Default RE: Help - Timing on 1963 Flat head
What model HD?
Old Apr 25, 2008 | 11:42 AM
panz4ever's Avatar
panz4ever
Jesse, gear timing is different from motor timing. Flywheel mark is used to time the motor; gears in cam case are timed to properly transmit engine power to the cam gears, crankcase breather, timer, oil pump and generator.
Old May 7, 2008 | 09:10 PM
OZIHOTROD's Avatar
OZIHOTROD
Stage I
The groove on the flywheel is used to set up the spark timing and not the cam timing, the cams will need to have all their timing marks in line with the pinion drive gear marks.
Old Dec 10, 2008 | 12:41 PM
charliea's Avatar
charliea
Go to this web site for a great timing tool http://www.techcycle.com/techaccessories.html
Old Dec 10, 2008 | 01:48 PM
FilthyLucre's Avatar
FilthyLucre
Will not work on a Flathead 45. It's made for the aluminum inner primary of a big twin.
Old Dec 15, 2008 | 12:33 AM
sepixlh's Avatar
sepixlh
I would guess that you have servicar ..you have not change cam timing ?
so issue is ignition timing ? do you have original adjustable distributor ? adjustment in handlebar ? adjustment in distributor ?
Old Dec 15, 2008 | 01:31 AM
Buddy7394's Avatar
Buddy7394
Default Timing a '63 G 45" Flathead
Well, the motor would be at least from a servi-car. (if not still in it).
"G" series 45" flathead...Last year before the 1964 GE (electric start servi)
Yes 1 year before the 65 Pan..
(as was posted) your pinion gear only goes on one way, align all cam timing marks off the pinion gear mark. And close it up..
Then roll motor over till front valves just close & watch for flywheel mark to be coming into window. Then you may have to pull out the timer & reset it.... That's about it..
Don't worry about cam marks matching the flywheel mark.. As long as you have timed the scav. pump (breather) gear & pinion gear to the cams.
Do you have an intake leak ??? That will cause poor performance...
fxhawg85
General Topics/Tech Tips
Nov 9, 2017 03:00 PM
Thejester
Engine Mechanical Topics
Jul 20, 2015 04:24 PM
Bumpandrun
EVO
20
Mar 27, 2013 06:59 AM
halmc
Ironhead
Jun 27, 2009 10:21 AM
deleontow
EVO
Sep 28, 2008 08:18 PM
