Whats Your 110 Dyno Numbers
Old 11-11-2012, 10:08 AM
cptdenny's Avatar
cptdenny
cptdenny is offline
Originally Posted by MRHH56
Did you feel the difference between stock and after the upgrade? How did it feel?
Oh yes! It was like getting a kick in the a$$ on acceleration. The throttle lag was removed by the tuner (Doc). My fuel mileage went from an average of 30 mpg to 40 mpg average. The bike runs a bit cooler. It now runs like a Swiss watch, sweet.
Local Gold Wingers no longer want to tango.
This is the way it should come out of the factory.
  #32
Old 11-11-2012, 02:29 PM
NYSport's Avatar
NYSport
NYSport is offline
2012 FLTRXSE full sac header pipe, 93hp and 112lb ft.
  #33
Old 11-13-2012, 06:08 AM
StreetJax's Avatar
StreetJax
StreetJax is offline
09 Ultra Classic CVO added Vance & Hines Power Duals & 4 1/2 pipes, SEPST.
Before
86.56 HP
104.68 Torque
After
94.14 HP
113 Torque
  #34
Old 11-13-2012, 08:54 PM
Mr. Funbag's Avatar
Mr. Funbag
Mr. Funbag is offline
1st Gear
Talking
2013 FLHRSE5
Screaming eagle supertuner with custom base map
Fullsac true dual kit
Fullsac 2" baffles
102hp
118 ft lbs trq
Wheelie pulling tire smoking hot rod!
  #35
Old 11-13-2012, 11:00 PM
onefastcorvette's Avatar
onefastcorvette
onefastcorvette is offline
Originally Posted by HDCrossbones09
Any dyno numbers on cvo 110? With or with out add mods.
My 2013 Road King CVO with full sack, rinehart, and SE tune and only 175 miles on the the clock had :
94 HP and 114 of twist.
  #36
Old 11-14-2012, 07:55 PM
Kingspoke's Avatar
Kingspoke
Kingspoke is offline
Default 2012 CVO Ultra - stock
2012 CVO Ultra w/TTS Mastertune & Dragula 2-1
97.89hp/116.84tq
Attached Thumbnails Whats Your 110 Dyno Numbers-flhtcuse7dyno.jpg   Whats Your 110 Dyno Numbers-20121113_125809-1024x768-.jpg
  #37
Old 11-14-2012, 09:09 PM
TheBig-O's Avatar
TheBig-O
TheBig-O is offline
Peak 117.8 FT-LB
Peak 105.0 Hp
V+H Power Dual Header
S.E.Super Tuner
Going to add 4" Rineharts and upgrade breather this winter . Will be interesting to see any change in my numbers .
  #38
Old 11-15-2012, 12:29 AM
FXDXTSport's Avatar
FXDXTSport
FXDXTSport is offline
Originally Posted by Black Diamond 110
11 SESG
Venilator AC (OEM)
Fullsac X pipe
Fullsac 2" baffles
TTS
95 hp / 108 tq
I have exactly the same setup and Dynoed at:
91HP / 103 TORQUE. One thing to keep in mind is that every Dyno is different based upon machine calibration and the operator. The real key is to get a Dyno run before making the mods and then one after to see what the mods really did for you. I wish I had done that
  #39
Old 11-15-2012, 08:52 PM
Glockmeister's Avatar
Glockmeister
Glockmeister is offline
(Must resist) (can't surrender) (must say no)
  #40
Old 11-16-2012, 03:30 AM
INZANE's Avatar
INZANE
INZANE is offline
SE 110
Heads by Deweys
Throttle body by HPI
SE injectors
D&D fatcat quiet baffle
SE 257 cam
TTS Mastertune
Quick Reply: Whats Your 110 Dyno Numbers
