Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Primary/Transmission/Driveline/Clutch
Primary/Transmission/Driveline/Clutch Find answers to general Drivetrain and transmission questions here.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 11-07-2009, 04:30 AM
Eyespy's Avatar
Eyespy Eyespy is offline
Location: Southern California High Desert, here and there....
Default Some trouble downshifting. Please help.
2000 Electraglide, has an Ultima 6 sp OD gear set.
Several thousand trouble free miles on the tranny, but recently developed 2 problems:
1) trouble downshifting from 6 to 5, such as when pulling up a long grade with headwind and have to drop down out of OD to maintain speed or accelerate. Shift lever moves down a stop, as if shifting, but stays in 6th often. Much less of a problem when slowing down to a stop and dropping down though the gears with throttle blips to rev match. But, this is where the 2nd problem happens:
2) Will shift down 6-5-4-3-2-N-1. No longer shifting from 2 to 1, but goes into N. Have to downshift again to get from N to 1.
Clutch seems to be adjusted fine. Fluid levels fine. Is the Ultima tranny a POS, or do these problems point to a likely and hopefully simple fix? Thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
Iron Order MC, California Chapter
IOFFIO/MBBM
Old 11-08-2009, 02:35 AM
Other Sheep's Avatar
Other Sheep Other Sheep is online now
Hard to say without more info. But I think I would change the tranny oil to a good synthetic like Mobil 1 75/140 and the primary to a good atf like trick shift from B&M and them take it out for a ride. Make sure the fluid levels are correct.
__________________
Old 11-08-2009, 03:33 AM
Eyespy's Avatar
Quote:
Thanks for your help, but those are all non-issues. It's something mechanical with the tranny.
__________________
IOFFIO/MBBM
Old 11-08-2009, 02:47 PM
Nightking's Avatar
Nightking Nightking is offline
Prospect
You need to adjust your shifter fork on the shifter arm. There is an adjustmnent that allows you to center the shifter at mid point , thus allowing you to shift up and down at the same pressure. Right above your shifter arm, there is a screw with a lock nut . That adjusts the fork that shifts up or down. The service manual should guide you through the adjustment process. If it is too far one way or the other, you will have problems shifting either up or down, depending on which way it is out of adjustment. The type of oil won't cause that problem. If you need more help, just PM me. It is a simple fix..
Hope that helps.
__________________
Old 11-08-2009, 03:59 PM
Eyespy's Avatar
Quote:
Hope that helps.
Thank you Nightking, I will look into that.
__________________
IOFFIO/MBBM
Old 11-08-2009, 04:23 PM
Eyespy's Avatar
I just checked, the shift pawl adjuster is set at mid-point. Maybe a bent shift fork?
__________________
IOFFIO/MBBM
Old 11-09-2009, 06:27 AM
Nightking's Avatar
Prospect
I would definitely take the top cover off and have a look see. You could have a bent fork somewhere .
__________________
Tags
davidson, downshifting, evo, harley, ioffio, mbbm, transmission, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
