Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Primary/Transmission/Driveline/Clutch
Primary/Transmission/Driveline/Clutch Find answers to general Drivetrain and transmission questions here.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 11-03-2009, 03:12 PM
janiharley janiharley is offline
Hang Around
Default Replacing drive belt
Softail 1988 50,000 miles
The manual says that the compensator nut is a bitch to get off, but I managed with just a large spanner, and didn't need to chock the primary chain! That worries me! One of you guys recently suggested I replace the entire mechanism cos if the nut come loose, it'll cause mayhem. I can see why. Don't know if the previous owner had any work done in this area, but it was looser than it should have been.
My question is this; I'm about to remove the clutch hubs but how do I undo the nut on the transmission shaft without the hubs rotating with the nut? The aluminium hub looks fragile so I don't want to chock it and end up damaging it. Also, I need to buy a puller. Can anyone describe the type that I need?
Finally, the manual says that I should probably replace the sprocket spring. Does this relate to my bike or a previous model?
By the way, a Harley drive belt in Scotland costs £223, about (US$360). No wonder Willie G. can afford a new hat!
Thanks again
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 11-04-2009, 10:13 AM
KBFXDLI's Avatar
KBFXDLI KBFXDLI is offline
Your comp nut will need to be retorqued to spec and use some loctite on it. (red). It will require some light heat to remove it again. Use a locking tool on the primary hubs and an air wrench to get the clutch hub nut off. Make sure you check the direction of the hub nut as it may be left hand threaded.
__________________
06 FXDLI
Many thanks to our people in uniform for it is their courage and sacrifice that makes our nation great.
Old 11-04-2009, 07:14 PM
ajayrk ajayrk is offline
Senior Rider
That model has a tapered main shaft to secure the clutch hub to the shaft and a woodruff key to keep it from rotating. As mentioned above the nut that holds it on is left hand threads and it is pretty tight.
I made a puller to pull that kind of hub. I used a 1/2" thick aluminum plate that was large enough to encompass the four towers that hold the spring in place. I drilled and tapped a 1/2-13 thread in the center of the plate and then drilled four 5/16" holes to line up with the four towers. Pass the four hold down screws through the plate and screw them into the towers. Thread the center forcing screw through the plate until it contacts the shaft end. Use something between the screw and shaft to protect the shaft threads. And be sure to remove the clutch push rod. Apply pressure with the screw. If it doesn't yield tap the end of the forcing screw with a hammer. Tighten and repeat. Be careful because those towers are fragile. Don't be surprised if you hear a loud pop when it comes off.
__________________
AJ
Old 11-09-2009, 02:27 PM
Hang Around
Thanks guys. That's really helpful. My local dealer told me that the transmission shaft is splined and that the hubs will just pull off! Musta got the model year wrong! He did tell me about a rubber chock put where the chain meets the sprocket that will aid removal of the compensator nut in future, or when torqueing it back up. Any home-based ideas about making one? Would a normal door stop wedge do?
Any thoughts about the sprocket spring?
Thanks.
Old 11-09-2009, 03:54 PM
bagga bagga is offline
i always use a screwdriver handle to jam the chain.
Old 11-09-2009, 04:18 PM
Hang Around
Thanks, Bagga. Smart idea
Old 11-09-2009, 04:45 PM
Dan89FLSTC Dan89FLSTC is offline
Prospect
If your bike was made in 1988, and still has the original mainshaft in the transmission, it is a tapered shaft, not splined. The splined shaft did not come out until 1990.
Old 11-10-2009, 09:07 AM
Senior Rider
Quote:
Originally Posted by dan89flstc View Post
if your bike was made in 1988, and still has the original mainshaft in the transmission, it is a tapered shaft, not splined. The splined shaft did not come out until 1990.
Yes, Yes and Yes!
__________________
AJ
Tags
belt, belts, clutch, davidson, drive, harley, hub, ironhead, nut, removal, replace, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
