Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Primary/Transmission/Driveline/Clutch
Primary/Transmission/Driveline/Clutch Find answers to general Drivetrain and transmission questions here.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-26-2009, 11:20 PM
TedChristian TedChristian is offline
Hang Around
Default Trans Vent leak
Have an 02 Ultra Classic w/70K miles blowing trans fluid out the vent. Changed fluid 200 miles ago always use HD fluid not syn. Just had the primary seals and drive belt replaced. Any help on what could be the cause. Thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-26-2009, 11:39 PM
dawg's Avatar
dawg dawg is offline
Could you have possibly overfilled it? The tranny on your 02 should take 20-24oz of fluid. I would run 22oz and use a good gear fluid.
__________________
'08 105th anniversary Ultra
D&D Fatcat
Zippers Redshift 575 cams
EVO Ind. 30 tooth
SERT
www.vtroaddawgs.com
www.roaddawgs.com
Old 10-27-2009, 12:15 PM
Hang Around
Default Tran Vent
Fluid level is correct turned the vent line straight up with a loop in it and it still blows fluid out???
Old 10-27-2009, 05:34 PM
rbabos rbabos is offline
Just throwing this out there. The primary vents through the pushrod hole in the gear box. If for some strange reason the crank seal took a dump excess pressure might be forced into the primary and into the gear box since it can only vent there. Long shot I know but checking this is easy. Place a low pressure gauge into the trans vent line and start the engine. If it starts to build pressure you have your answer. Might only be in the 1-3 lb range, and will show up as a pulse, not steady.
Ron
__________________
07 Softail Custom
V&H BSS
Screaming Eagle Heavy Breather
Screaming Eagle Big Twin Compensator
Tmax
Harley Blade 41681-07 wheel
The puppy lasted until fall. Now in teardown mode for new build
Old 10-27-2009, 08:00 PM
Dan89FLSTC Dan89FLSTC is offline
Prospect
If the crank seal on the left side is allowing pressure to escape to the primary, you will probably find that the primary has too much fluid in it,and the engine oil would be low.
Also you might want to check the vent line to be sure it is not obstructed.
Tags
harley, leak, trans, transmission, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
