Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Primary/Transmission/Driveline/Clutch
Primary/Transmission/Driveline/Clutch Find answers to general Drivetrain and transmission questions here.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 07-18-2009, 10:52 PM
seniorsuperglideE8 seniorsuperglideE8 is offline
Installed the Hayden M6 on both bikes. Two springs under the shoe keep the chain just right, hot or cold.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
tailhook seat plumber
02 FXD 95" BB, 203 cams, low restriction mufflers
05 FXDLI, stage 1, low restriction mufflers
Old 07-22-2009, 07:49 PM
OneBlackFly OneBlackFly is offline
Quote:
Originally Posted by rbabos View Post
There is no slack when it adjusts itself. The chain may appear tight but there is an aditional 1/2" of spring in the shoe to allow for tightening from heat. If you try and adjust it the same as a solid shoe it will take this slack up to it's designed tension right away. That's ok.
If you give the ratchet a helping hand and force it 1 more click than it would naturally want to do, then you can run into losing the remaining shoe spring when hot and cause an overtight condition. Just cut the tie wrap and walk away from it. It will set itself and work fine. Two exceptions that could promote over ratcheting are beating the bike before a good warmup, or brutal torque from a non stock engine can between the extra pull on the chain, which has some elastisity and shaft deflection might allow the ratchet to end up going tighter than it should.
Ron
Bottom line - if installed correctly without forcing the shoe upwards on installation, all is well. Where then are the springs in the bottom of this unit? From what I've seen, there aren't any. What am I overlooking? Thanks.
__________________
... Paul ...
Old 07-22-2009, 08:09 PM
rbabos rbabos is online now
Quote:
They are under the shoe. Two , if I remember correctly. When the chain is tight on the top from the ratchet, these give an additional 1/2" more or less to keep the system from going totally rigid, like when the chain gets tighter from heat. Consider this as the working zone, and the ratchet as basic initial adjustment.
Ron
__________________
07 Softail Custom
V&H BSS
Screaming Eagle Heavy Breather
Screaming Eagle Big Twin Compensator
Tmax
Harley Blade 41681-07 wheel
The puppy lasted until fall. Now in teardown mode for new build
Old 07-23-2009, 07:12 AM
Ron
This is good to know since over this next winter, I plan to installed one of the H-D units.
__________________
... Paul ...
Old 08-02-2009, 04:24 PM
MixedNuts MixedNuts is offline
Prospect
Well guys for what it's worth I just listed it on e-bay. Hope this is appropriate:
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMESELX%3AIT
__________________
Pete
Old 08-03-2009, 04:16 PM
TFTCAR's Avatar
TFTCAR TFTCAR is offline
Prospect
Smile
I used the aftermarket hydraulic chain tensioner on Booth my bikes, they have performed flawlessly and I would highly recommend them. Easy to install and then forget about them.
__________________
TFTcar
Tags
adjuster, adjusters, automatic, chain, clunk, davidson, eagle, harley, neutral, primary, screamin, set, swap, tool, wrap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
