Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Classic > Panhead
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-11-2009, 11:08 AM
Phillip Phillip is offline
Hang Around
Default Panhead distributor
Does anyone have a diagram of a single point dist. for a 60 pan? Just got mine running but anything over idle and she spits and sputters and dies. I am running a cv carb. Any ideas that you think will help would be greatly appreciated.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-11-2009, 01:18 PM
sqdealgeorge sqdealgeorge is online now
Pts set at .022 (narrow lobe ) How about timing ? As you probably know timing is off the front cylinder If timing is a problem let us know we'll walk you thru it I take it your using a CV plate adapt off the stock manifold
Old 10-11-2009, 01:26 PM
Hang Around
Yep stock manifold adapted for cv. I think the timing is ok, ran great at idle just didnt want to rev up. I was thinking the weights might be stuck. Points are set at 22.
Old 10-11-2009, 02:10 PM
Hang Around
Don't know if timing is off, but please give me the steps to check it.
Old 10-11-2009, 06:26 PM
There shouldn't be any weights ! Let me know how you timed it or call me at 608-847 -4240
Old 10-12-2009, 07:37 PM
Hang Around
I pulled the timing plug put the line dead center, then checked to make sure points were on small side and lined up.
Old 10-13-2009, 10:18 AM
Remove spark plugs Remove pushrod clips on front cyl pushrods rotate the engine till the front pushrods are at the bottom of the cam if the rods were adjusted properly you should be able to spin the rods with your fingers (tight spin ) now go look into the timing hole At this point I like the rear wheel off the ground the trany in 4th gear rotate the wheel slightly either front or back till you see the flywheel mark come into view I time the 46knuck and the 52 pan with that flywheel mark at the rear of the timing hole I think the 60 pan should be in the center ? close enough Now real quick go see if the front pushrods still spin At this point the circuit breaker aka distributor shuold have the narrow lobe just opening the points NOT .020 but .001 I use a 12volt test lite to check the points at this point (my bikes are all 12 V ) If at this point the fat lobe is opening the points you will have to pull the circuit breaker (distrib ) and rotate the splines that drive the circuit breaker till the narrow lobe is lined up with the points Confused ? I am let me know the outcome
Old 10-13-2009, 05:42 PM
Hang Around
I wont be able to try it until friday but I will do it then and let you know how she does. Thanks for the advice.
Old 10-14-2009, 01:20 AM
cole cole is offline
Hang Around
Try changing the condenser. Do NOT use Accel. cole
Old 10-15-2009, 08:37 PM
Hang Around
Thanks Cole. I am going to change it and the points. Got new plugs as well.
Tags
carb, cv, davidson, distributor, distributors, electronic, harley, iginition, intake, lobe, manifold, narrow, panhead, points, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
