super e problems
Old Apr 30, 2008 | 02:34 PM
smallmouth6810's Avatar
smallmouth6810
2nd Gear
Default super e problems
i have a 56 pan and the super e on it and i get fuel to the bowl but wont start if i cover carb with my hand and kick it two times the fuel enters carb and will start then stop no flow help me i cleaned carb and made sure that there was no pluged jets all o ring there im stumped
Old Jun 4, 2008 | 04:09 AM
SloRoll's Avatar
SloRoll
6th Gear
Default RE: super e problems
Super E has an enrichner not a choke. When you cover the carb with your hand you cut off the air going over the enrichner port and no fuel is drawn up. Enrichner on, a couple of priming kicks then enrichner off, ignition onand kick. Depending on the bike you may need to just leave the enrichner on until it's running.
Old Jun 4, 2008 | 04:12 PM
pittguy's Avatar
pittguy
If you had the bowl off check to see if ejector oring is still there.Item #40 on parts breakdown.This oring is famous for sticking enough and falling off unnoticed.Will cause the symtoms you describe.Idle problem could also be an intake leak,improper idle mixture or idle rpm setting.Rare but also sticky advance.
All Aces
EVO
16
Jul 12, 2014 06:27 AM
Hey Zeus
Shovelhead
Aug 1, 2013 07:22 AM
1.HD.ROCKS
May 20, 2011 06:49 PM
scotitude
Oct 30, 2010 11:10 PM
elevenbravo78
EVO
Apr 6, 2010 09:49 PM
