Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Do It Yourself Help Forum > Oil Related
Oil Related Tips on oil related items, to include oil coolers.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 09-17-2009, 08:23 PM
baldric baldric is offline
Prospect
Default Oil Grade
My brother has a 2009 Fat Bob. He had the oil changed on the first service and was wondering if the 20W50 in the motor is the same oil used in the tranny? The reason he asks is the dealer insists it's the same in both holes and he has his doubts. Don't reply with the " get a service manual" It's on order as we post.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 09-17-2009, 09:18 PM
Heath's Avatar
Heath Heath is offline
Platinum Sponsor
Must have done the Syn3 20/50? That one they can in all THREE holes. As long is it is wet clutch compatible as most motorcycle oils are, it can be used in the primary. It can be used in tranny as well but many use gear lube. He's good.
__________________
Heath Palmer, AMSOIL Regency Direct Jobber
website: www.thesuperiorsynthetic.com
641-420-6677
email: thesuperiorsynthetic@hotmail.com
Purchase Options Available
Contact mefor wholesale prices
Bike: 2009 Street Glide
Old 09-17-2009, 10:04 PM
Prospect
Thats good to hear. Damn I forgot about the primary. When he asked me he was more concerned about the trans so I never even thought of the primary. Thanks.
Old 09-18-2009, 04:34 PM
1550vt 1550vt is offline
Senior Rider
If they put the syn 3 in all three holes, they need to go back to Harley School. I believe the MOCO no longer recommends that. They had some transmission issues running the 20w50 in the transmission. They did it despite of the warnings from the motorcycle world-at-large that it was too thin. Personally, I tried it and got to the end of my driveway, came back and changed it to gear oil. Sorry to say it was Amsoil, but I am not trying to start an oil argument as I think syn 3 would have netted the same results. I don't think anything but a good grade of gear oil should be in the transmission and some guys run 85 and others run a multi-viscosity like a 75w-140. It's fine for the primary, but HD is using a product called Pro Gold now and may even be putting the same in the transmission. I would ask myself, if I had a car with a manual 5-speed transmission, would I put motor oil in there.
Having said this, I am sure there are lots of folks out there running the 20w50 in all three holes with no issues. I just could not do it and make mine shift and I know of many others that would not do it either. Transmissions will perform differently using various types/grades of lubricants and your brother will find out what works best for him as time goes by.
Old 09-19-2009, 08:46 PM
Senior Rider
I realized that I misspoke in the above post. HD is using Formula Plus in both the primary and the transmission and not Pro Gold. My local dealer no longer puts the syn 3 in the transmission and since Harley has discontinued the primary fluid, the replacement product is the Formula Plus.
Old 09-19-2009, 11:42 PM
pococj's Avatar
pococj pococj is offline
Quote:
Originally Posted by 1550vt View Post
(Snip some) They did it despite of the warnings from the motorcycle world-at-large that it was too thin. (Snip some) ...and some guys run 85 and others run a multi-viscosity like a 75w-140. (Snip some)
Are you aware that engine oil and gear oil viscosity scales are not the same? The viscosities can not be directly compared. 20w-50 engine oil is about the same actual viscosity as 75 - 90 gear oil. And 140 gear oil is generally equivalent to 60 motor oil.
SAE Engine Oil vs. SAE Gear Oil
10w thru mid range of 20w = 75w
Mid 20w thru mid 30w = 80w
Mid 30w thru low 40w = 85w
Low 40w thru 50w = 90w
60w up = 140w
__________________
Brotherhood of Warriors Veterans Motorcycle Club
WFFW
BGBB Support Member
Old 09-20-2009, 07:40 AM
Senior Rider
I agree that the viscosity ratings cannot be compared and just saying that motor oil is too thin may not have been the correct thing to say. I think we can all agree though that gear oils are blended and have additives suited for a specific purpose other than motor oil blends. Motor oil may work just fine in the transmission and I know some aftermarket manufacturers recommend it as well as lubricant manufacturers. I just found it a little strange that the MOCO is still putting the syn 3 in all three holes. I thought they had drifted away from that. I know some dealers are now using this Formula Plus.
Old 09-20-2009, 11:35 AM
prodrag1320's Avatar
prodrag1320 prodrag1320 is offline
Prospect
I always,right from the start,dissagreed with putting ANY 20/50 in a transmission,never would do it in my shop
kirby
www.veetwinperformance.com
Old 09-21-2009, 08:49 PM
big cahuna big cahuna is offline
I run 20/50 wt gl1 rated oil in my heavy '03 ultra classic trans. Have been doin so since it was new. It gets used thru the summer in temps up to 100 degrees, and thru out the winter in temps down to 15 degrees. So whats gonna happen and when?.,,
Old 09-21-2009, 08:59 PM
Notgrownup's Avatar
Notgrownup Notgrownup is online now
I used 20/50 in all 3 holes unti 30k miles then i put severe gear 75w140 i think in the trnny...smooth it out a bit but still use aMSOIL or Mobil 1 in the primary. Lot's of opinions here...most are good opinions...Nobody has stear me way off track yet.
Tags
2000, 30w, blend, brands, davidson, formula, grade, harley, hd, motor, oil, recomennded, trans, transmission, types, viscosity
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
