This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________ Life's a ride and it's a lot more exciting on a Harley. Mine: 07 Road King Classic (FLHRC)
Pewter Pearl, V&H True Dual Classics, PCIII
Hers: 03 Heritage Classic (FLSTC)
Vivid Black, 100th Anniversary, V&H Longshots,
I just switched out the Amsoil 20/50 wt oil in my primary to Valvoline mc 20/50 wt oil. The Amsoil has 10k miles on it and seemed a little stiff when shifting. I used the Valvoline do to the fact I didn't have any Amsoil, and wanted to try something and cheaper. It made a big difference in the shifting. Just a click and no banging while shiting into first. I will be using this oil for a while just to be sure its the real thing. For $3.99 a qt you can't go wrong.,
Put Spectro 6 Speed Tranny fluid last week in the new glide, really smoothed out the shifting. Definitely tell the difference. Put Klotz Synthetic Primary Chain Case Lubricant in yesterday, but was raining after so haven't got a chance to see how it will be. Still runnin' the 20/50 HD dino in the crank though until I get at least 1500-2000 on it and then probably go to M1 VT after that.
__________________ Keep your friends close, but your enemies closer.
My primary is an inch low but i do not know what is in the bike as i just bought it--supposeidly redline?? What would you do ?/ Drain or add what??-thanks in advance--Glenn
__________________
2002 Deuce --"Harley calls it "smoke on the water"?? Wife calls it Purple?? What say U??
What ever one uses in the primmary it "must be for wet clutch operation" or the clutch will start slipping, so beware it will destroy the clutch and some lubs faster then stink. I would not use a gear oil in the prim.. If it does not say for wet clutch on the bottle or in the specs., then I would not use it and if one has it in the prim., I would change out real fast. Amsoil says to use their 20W50 in the prim with the secound choice being their 10W40. The 10W40 would be for colder temps as the service manual says to use for use in the engine so would be for the prim., also. You can use too heavy an oil in the prim., or engine for that matter so may be best to pick based on temp., you plan to ride it in. Oil itself will create friction if it is too heavy a weight.
