need help 01 electra glide oil change
i dont have a mannual yet, and need to do an oil change and tranny and primary all at once last time i did it there was a website i went to that gave step by step directions, that helped very good, does anyone have pics or step by step? i know there is a plug that i am not supose to loosen>? any helps or tips would be great, i will buy a manual after this oil change i promise, lol
pics are always great and help a ton, OR vids,,, thanks in advance,.,.
![Icon Twocents](https://www.hdforums.com/forum/images/smilies/icon_twocents.gif)
See attached photo 1 of plug locations if looking at pan from front of bike. Only put in 3.5 qts of oil and 22 oz of tranny fluid and 1 qt primary fluid. See attached photo 2 for your primary plug location. Tranny and Oil plugs use a pn#11105 o-ring or a -13 if you are getting it elsewhere. Also, don't forget the oil filter. Can be messy when removing if you don't take the precautions. I fill my new filter up 3/4 full with oil prior to spinning it on. Easiest to fill the primary back up through the chain inspection cover on your bike.
You can but you should'nt. Use a gear oil in the tranny, any 10w40 in the primary and a good grade 20w50 in the crankcase.
I use Belray Bigtwin in the gearbox, Belray Primary and Redline 20w50.
