Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Oil and Oil related topics
Oil and Oil related topics A place to post your oil related questions and comments.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 02-15-2008, 12:40 AM
KBFXDLI's Avatar
KBFXDLI KBFXDLI is offline
Default RE: gas smell in the oil
Quote:
ORIGINAL: Twisted Humor
It could be many of these ideas, but I would bet on the rings because of the age of the bike. If the rings are worn then on the compression stroke a little fuel would be forced past the rings into the crankcase.
Yeah but blowby will usually get burned off and only leave microscopic traces of fuel because it occurs while theengine and oilis hot. This guy can actually smell gas in the oil which means he has some serious dilution going on.I had a brand new Sportster that would leak fuel into the oil if you didn't close the fuel shut off valve. Turned out the valve was defective. So, my guess this guyhas a bad fuel shut off valve. Ifthe bikestarts and runs wellI would replace the fuel shut off valve and start using it all the time and just do a few carb cleanings to see if that is the issue.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
06 FXDLI
Many thanks to our people in uniform for it is their courage and sacrifice that makes our nation great.
Old 02-15-2008, 01:29 AM
Twisted Humor's Avatar
Twisted Humor Twisted Humor is offline
Quote:
ORIGINAL: KBFXDLI
I am not trying to be all knowing on the subject, but doesn't the blowby happen on the compression stroke when the fuel mix gets compressed in the combustion chamber, it will blow by the rings into the crank case? It can't get burned off in the crankcase. Now if the oil from the crank case was blowing by the rings into the combustion chamber, then yeah it would burn off. But you would probably have a lot carbon build up in thecombustion chamber.
Just my thoughts while being fully marinated, but someone teach me something when I wake up.
__________________
*********** GM Card / HSBC will allow a business to guess at your expiration date for your credit card to force a charge through and then let the charges stick. It has been my experiance that GM Card / HSBC will not protect their customers of this fraudulent activity. ************
Old 02-15-2008, 11:20 AM
98glider 98glider is offline
1984 harley sportster
I am going to change the oil and filter I am going to use 20w 50 pennzoil in the 84 ironhead just don't want to waste new oil then I am going to put 20w50 harley for NJ weather again to get the rest of it out.I am going to check the petcock by diconnecting the fuel line to see if that is good. I am going to take the air cleaner off the s&s carb and take a look at the carb and the diaphram, needle and seat. just visual, is there going to be anything obvious that I will notice that might be bad? Thanks Charly
__________________
"Miles are kept by how many times you fill up"
Old 02-15-2008, 12:03 PM
SportsterBob's Avatar
SportsterBob SportsterBob is offline
Quote:
ORIGINAL: 98glider
I have a s&s carb. Does the oil change color Also can the bike get flooded and eventually get blow by. the bike seems to run good. Is there any other test I can do I don't know much about the S&s carb Thanks again charly
A quick way to see what's going in the cumbustion chamber is to read the spark plugs. If they are black, the engine is running rich. If they are a wetish black, use your sense of smell...it could be wet with gas or oil. Those ironheads are notorious for running dirty what with the full hemispherical cumbustion chamber and domed pistons. Watch for black smoke in your exhaust.....that is a sign of running rich.
__________________
There's never enough time to do it right but there is always enough time to do it over!
CV-67 VAW-126 Med-Cruise,1986
http://hdforums.com/forum/members/sportsterbob-albums-pics-picture24299-bikes.jpg
Old 02-15-2008, 12:18 PM
You are right. I am going to do that when I get home. I just went to the dealer to get a new oil filter. I also asked his opinion and he said those bike had those problems and he said change the oil and see if the smell comes back.
__________________
Old 02-15-2008, 12:37 PM
DeJavu's Avatar
DeJavu DeJavu is offline
Quote:
ORIGINAL: 98glider
Now the needle in the S&S carb is under the diaghram. Now the seats are located where in the carb Thanks
I'm not sure I understand your statement, but there is no diaphram or needle in an S&S carb. If you are refering to the float needle valve, it is at the topabove the float bowl held by the float assembly, the cooresponding seat is screwed into the carb body at the fuel inlet.
__________________
You find out who your bros are when you ride a kick only bike.
Old 02-15-2008, 12:43 PM
I am not familiar with the S&S carb I have stosk carb on my98 fxd. So the carbs are different. Can you explain if this can happen that gas can get into the oil Thanks Charly
__________________
Old 02-15-2008, 12:44 PM
KBFXDLI's Avatar
Quote:
ORIGINAL: KBFXDLI
The fuel will get evaporated (burned off if you will) in the crankcase when the oil gets hot leaving only corrosive elements of the gasoline that don't evaporate but they are in all engines and don't smell like gasoline. These combustion byproducts are a big part of what turns your oil black with use.If this bike had so much blowby past the rings that unburned gasoline is making it past there in enough quantity then his performance would be horrible and the bike would smoke like a chimney. I could be wrong but I think he has a fuel leak somewhere. I had the same issue with my sportster. The oil stunk like gas. That is how I noticed it when changing my oil.
__________________
06 FXDLI
Old 02-15-2008, 12:50 PM
KBFXDLI's Avatar
Quote:
ORIGINAL: 98glider
I'll bet if you disassemble and clean the fuel petcock and use it all the time to shut the gas off when the engine is off......then run some gumout through your fuel system you issue will be solved. One question: Has this bike been stored without fuel stabilizer in the gas? If so, it may just have some varnish on the carb internals.
__________________
06 FXDLI
Old 02-15-2008, 02:30 PM
Thanks kb giving me the time and hopefully it is something simple and explaining to me how it works. I will add cleaner and check the petcock. Thanks Charly also the bike did sit around but for how long i don"t know
__________________
Tags
2009, burning, davidson, dilution, efi, fix, fuel, gas, gasoline, harley, oil, prevent, smell, sportster, strong, temp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
