630 amp blinking out
I recent purchased the new j&m rokker 630w amp along with the 6.71 front fairing speakers. I had the 360w amp and the 6.65 front fairing speakers the sound was amazing. This new setup got me puzzle, when I increase the volume the amp goes into protection mode. The amp is cutting off but if I unhook the rear speakers the amp works fine. I'm running the same 6x9 speakers I had with the 360w amp. Does anyone know what could be the cause for the amp blinking out. I tried downloading the dsp software that is offer for the system setup no resolves. The amp behaves the same the only different I can see, if the bike is idling I can increase the volume without the amp blinking out. But once I give it a little gas the amp cuts out!!!! I followed the instructions to the letter as to where to put the ground and power wire. I checked if I had any exposing wires, I have none. My radio hasn't been flash from the factory setting. Can anyone out there tell me what's going on or had this problem?
capnkirk ,,,,,,,
has our service department taken care of you yet on the amp issue ? ,,,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
No
No, I feel as if I'm talking Greek....The execute command file doesn't exist in the dsp software I need to properly run that amp. I understand it's a new a amp with new software but I truly feel that I'm completely alone with no help. I bragged on jm when I had my first system 360w amp and 6.65 fronts, the speakers wasn't all that but the amp made up the difference, now I'm smh and hating I spent all this money on %^*+. With no tech support not even a courtesy email,saying I'll get you the help.
captnkirk ,,,,,
have you been given the correct download for your amp and have it installed now ? ,,,,
if not send email direct to audio@jmcorp.com and I will set up a drop-box folder for you and put the correct DSP download in there, to make it easy for you to install ,,,,,,
