Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Classic > Ironhead
Ironhead A place to talk about Ironheads.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 08-28-2009, 02:08 PM
pickupman96 pickupman96 is offline
Hang Around
Default cam shim/bushing question
first question i have is what side do the cam shims go on, the case side or cover side. If cover side what do you use for a shim on the second cam from the rear. It is a much larger diamiter than the others and none of the shims will fit over it. Second i see in pics that there are small pins that go between the bushings and cam??? I see on 3 of the bushings there are slots but when i took it apart i did not find any and I cant seem to find any to buy. Do I really need those or will she work without them. Thanks for the help in advance.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 08-28-2009, 05:48 PM
IronMick's Avatar
IronMick IronMick is offline
Quote:
Originally Posted by pickupman96 View Post
1. what side do the cam shims go on, the case side or cover side.
2. what do you use for a shim on the second cam from the rear.
3. there are small pins that go between the bushings and cam???
4. I see on 3 of the bushings there are slots but when i took it apart i did not find any and I cant seem to find any to buy. Do I really need those or will she work without them
First shims are unnecessary. HD published a service bulletin about this. Here is a link for download:
http://cid-e2880b68d32bbca8.skydrive...vcBullM860.pdf
When i shimmed mine i put them on the cover side except for the #2. I think it does not matter. I have heard of guys splitting them etc. I have since removed them all.
The pins are HD part number 275, DOWEL PIN, 1/8 X 1/4. You drill a hole thru the lip of the bushing into the case and drive in the pin. This is to prevent the bushing from spinning. New bushings that you buy, even those especially for this application, may not have enough lip to do this. For these just get them in there really tight - heat the cover in the oven, cool the bushing in the freezer, press it in perhaps with some red locktite.
The slots in the bushings are absolutely necessary for oil flow.
25586-37 cam gear shaft bushings [3]
25588-57 #2 bushing
25593-74 flywheel gear shaft bushing
25597-57 gen idler gear shaft bushing
__________________
Mick
IronHead Forever!
Old 08-29-2009, 06:52 AM
piniongear's Avatar
piniongear piniongear is online now
What are you doing regarding the bushings and the timing cover?
If you are replacing the bushings in the cover, then I hope you have the engine completely dis-assembled.
If you are just putting in new bushings in the cover, then you may find you are making a serious error in doing so.
I hope you are aware that new bushings must be line reamed with the right side crankcase and timing cover fastened in place.
The reamer goes through the other bearing(s) in the case and reams/aligns the new bushing(s) to size after they have been pressed into the cover.
Just thought I would mention that in case you are not aware of it..... pg
__________________
Rolling down the highway on two wheels since 1957...
Owner Red/White 1971 XLCH & 2003 FXDL-Silver over Black
Old 11-04-2009, 11:43 PM
seventyiron seventyiron is offline
Hang Around
Old post i know..but the shims should go on whatever side of the cam that aligns the lobe to the tappet wheel the best. As close to centered as possible.
Old 11-05-2009, 07:38 AM
piniongear's Avatar
Quote:
Either side, it makes no difference. I like to stick them between the backside of the cam and the cam plate myself.
You are gonna hear some say you do not need any shims. That is because of a tech service notification made sometime around 1978 saying shimming is not required.
Well, I require shims myself and will always use the shims on my machine. We each make our own choice on this one.
pg
__________________
Old 11-05-2009, 08:17 AM
IronMick's Avatar
Here is a link to the service bulletin on my SkyDrive account. Click on DownLoad to get it ...
__________________
Mick
IronHead Forever!
Old 11-06-2009, 07:57 PM
Hang Around
Wow..
I don't use them on 1976 up,but 1975 down always,unless the Andrews PB+ are used.
(That way,both the folks I admire are happy)
Tags
2558637, bushing, bushings, cam, camshaft, evo, harley, hd, ironhead, shim, shims, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
