Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Classic > Ironhead
Ironhead A place to talk about Ironheads.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 08-10-2009, 09:41 PM
sousap sousap is offline
Hang Around
Default Spark plugs
Another quick question if I may.
I noticed that the spark plugs in the bike were not the correct ones that the book calls for, I called the previous owner and he said that he put those because the original plugs would not last very long.
Is there any reason to run plugs other than the correct ones?
The only thing I can think is to get a hotter plug to overcome something else wrong.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 08-10-2009, 10:06 PM
shepdog's Avatar
shepdog shepdog is offline
Prospect
i would look for the problem,maybe try to adjust the carb to start,are they oil fouling or gas? i change my plugs once a year, even then they are fine, i just do it dont have to
Old 08-10-2009, 10:08 PM
Hang Around
All black, bike is running good.
Old 08-10-2009, 11:01 PM
IronMick's Avatar
IronMick IronMick is offline
Quote:
Well, if the plugs are all black the bike may be running good, but not good enough. If the plugs are getting carboned up then so is the combustion chamber, the piston tops, and the valve guides. Best to un-richen it.
What carb? What jets? How many turns out on the pilot screw?
__________________
Mick
IronHead Forever!
Old 08-10-2009, 11:25 PM
Hang Around
Mikuni H5, I have not touched the carb so I do not know the other answers.
It it helps I am running stright drag pipes.
Old 08-10-2009, 11:32 PM
IronMick's Avatar
I am not familiar with that carb, but here are my carb cleaning notes. Written for a Keihin carb but the principles and procedures are pretty well all the same.
1. Removing it from the bike should be straight forward. First thing when it is out is to check the pilot screw setting. Turn it all the way in until gently seated counting the number of 1/4 turns; then write this number down; then reset it.
2. I put mine in a vice to remove the screws, and for much of the following work. Wrap in a shop towel; close the vice gently taking extra care with the choke and throttle linkages. The vice is a needed extra pair of hands.
3. You must be very careful handling the float so as to not change the level. You must have the official specs for setting the level as in the FM, and check it, every time you dismantle the carb, as the last thing before putting it back together.
4. The jets are made of brass, a soft metal that is easily damaged. Use an exact correct size screwdriver. I ground a medium flat blade screwdriver down to exact size on my bench grinder to access the slow jet.
5. The general appearance of the inside of the carb is not necessarily a good indication of its condition. It can look spotless and have clogged jets, or look cruddy and have clear jets.
6. Ignore any advice that says to soak or boil the whole carb in carb cleaner. Rather, clean each individual part. Do not allow any solvents to contact any rubber parts [tip of needle, o-ring seal for bowl]
7. Make a list of all of the jets and passages for your carb using the carb manual or the FM for the bike. Then ensure that you can blow either compressed air or carb cleaner thru each one.
8. Remove the pilot screw and clean the parts and the passage. The passage contains in this sequence: pilot screw, spring, washer, o-ring. These are very small parts, especially the washer and o-ring. Usually the spring will easily fall out. One time i thought the spring was not in there because it would not fall out; i obtained a new spring and could not get it in! The technique for removing the washer and o-ring is to use a pipe cleaner: stick it in the hole, twist it around, remove it - you should see the washer and o-ring on the end of the pipe cleaner.
Remember that the purpose of the washer is to protect the o-ring from the spring and you will always get them back in in the correct sequence.
9. Dismantle the accelerator pump assembly noting carefully the sequence and orientation of the parts. Clean and inspect the parts. Replace the diaphragm if it is cracked.
10. Check the float level then carefully put it back together. I personally find it very confusing trying to decide which way to bend the tang if it is not correct. If the fuel level is low is the float high or low? Do i need to bend the tang up or down? On the bench the carb is usually upside down, adding to the confusion. Sort all this out before making an adjustment.
Best to replace the original Phillips screws for the bowl with stainless steel socket head screws.
__________________
Mick
IronHead Forever!
Old 08-12-2009, 08:19 PM
Hang Around
Ok, I am getting a little cofused what carb model it is, the only thing I can find in the carb is H5, I attached pics can someone tell me where I would find specs for this carb and are there parts available?
Old 09-27-2009, 11:05 PM
seventyiron seventyiron is offline
Hang Around
Looks like a VM38..one of the best carbs Ya can put on a IronHead.
Parts are found at Sudco,I will get Ya a link,and you can Google it also.
All You should ever need is gaskets!
Old 09-27-2009, 11:56 PM
piniongear's Avatar
piniongear piniongear is online now
This is a month and a half old thread but perhaps this info will help someone out.
Ditto that! Best carb you could hope to have on the Sporty. Looks like a VM38 to me as well.
This would be a 38mm round slide carb. 38mm is the correct size for a Sportster. A 40mm carb is made to fit a big twin, so if this turns out to be a 40mm, it is too large to be running on a Sporty.
Anyway, the carb slide has a needle inside the slide.
Remove the screw top and carefully remove the slide and throttle cable.
The slide needle will have 5 notches in it and a clip secures the needle in place.
The clip must be in the middle notch. That is the third from the top or the third from the bottom. This sets the position of the needle's tapered end in the main jet below.
Other than that, leave the carb alone if the bike starts and runs OK at present.
I have run a Mikuni since 1973 and this same carb has never needed anything, not even a throttle cable replacement.
As was said..... parts from Sudco or one of their distrubuters......... pg
__________________
Rolling down the highway on two wheels since 1957...
Owner Red/White 1971 XLCH & 2003 FXDL-Silver over Black
Old 09-28-2009, 11:13 PM
Hang Around
http://www.sudco.com/mikuni.html
they show a improved intake manifold,later model uses one clamp rather than two..comes with the kit,along with a K@N filter.Also,if You prefer the factory air cleaner,look for a Branch flowmetric adapter..ebay maybe? (hard to find)
I use Accell plugs with my VM38s, # 168 (nice brown color to em)
Tags
bad, clean, davidson, h5, harley, hotter, ironhead, mikuni, nonresistor, plug, plugs, purchase, putting, sizes, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
