Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Classic > Ironhead
Ironhead A place to talk about Ironheads.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 05-20-2009, 12:45 AM
roadway873 roadway873 is offline
Hang Around
please do i will take any info I can get E--------jeffdille@comcast.net-----------
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 05-20-2009, 12:52 AM
Hang Around
according to my book there are 4 major parts -pump adj. screw------------idle mixture screw--------throttle stop screw-----rocker arm---is the pilot screw the same as the idle mixture screw or the pump adj. screw???????????
Old 05-20-2009, 06:19 AM
IronMick's Avatar
IronMick IronMick is online now
Pilot screw == idle mixture screw.
Pump adjusting screw probably adjusts accelerator pump
throttle stop screw == idle speed screw
__________________
Mick
IronHead Forever!
Old 05-20-2009, 10:35 AM
carlgrover's Avatar
carlgrover carlgrover is offline
Quote:
Originally Posted by roadway873 View Post
any tips on adjustments? went for a ride the other day, ran kind of bad then all of a sudden, ran perfectly out of the blue except idled real fast. Checked plugs @ home and they were all carboned up, plus bike seemed hot-need adj. tips------got any?
Before you start tinkering with the carb you had better check your intake manifold for leaks. That real fast, hot, idle smacks of the famous intake leak.
__________________
Don't worry, you'll be alright. After all, everyone knows that bees won't sting an idiot.
Old 05-20-2009, 12:19 PM
Hang Around
Thanks you've been a freat help----jeffdille@comcast.net
Old 05-20-2009, 03:09 PM
FilthyLucre's Avatar
FilthyLucre FilthyLucre is offline
Senior Rider
Help I can't ID the carb on my 76 ironhead-------------all it says is AMF Harley Davidson Japan ---any ideas and if so how to adjust-If it says Japan does it have to be a Kehin?????????????????????????????????/
Early 76 Ironheads had a bendix carb. In late 76 they introduced the Keihin. This was a butterfly carb not to be confused with the later Keihin CV carb on the evo's. They have had several models over the years. If it has a fully adjustable low speed mixture screw. (the one closest to the manifold flange) it is a 1976 model. If it has a plastic limiter cap it is off a 78 or 79 model. If the low speed needle is hidden by a plug it is an 80 or latter model. The 1976 model was the best of the bunch. They all came with a label telling the part number but that usually didn't survive cleaning. Set up properly they were basically fool proof. I ran one for 25 years and never had to readjust it.
__________________
57 FLH
68 FLH
72 FLH killed 12/15/08 by an SUV
75 FXE
69 LE
Lű cre (kər) n. {OFr. Lucre, from L. Lucrum, gain. Riches; money: now chiefly used in a humorously derogatory sense; as in Filthy Lucre
Old 05-20-2009, 03:36 PM
piniongear's Avatar
piniongear piniongear is offline
But a Bendix is not going to be stamped 'Japan'. In the 1970's Bendix was a made in the USA item, and hopefully still is today.
If the OP needs info on tuning a Bendix then I have all the info he could hope to have. Just ask........... pg
__________________
Rolling down the highway on two wheels since 1957...
Owner Red/White 1971 XLCH & 2003 FXDL-Silver over Black
Old 05-20-2009, 11:04 PM
Hang Around
best info received so far---------thks---------jeff
Tags
76, adjust, amf, bowl, carb, check, cleaner, davidson, dirty, float, harley, increase, ironhead, japan, keihn, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
