Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Classic > Ironhead
Ironhead A place to talk about Ironheads.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 05-13-2007, 07:36 PM
SKJOLD SKJOLD is offline
1975 Harley Davidson Sportster
My Garage
Default Shovester
I have been toying with the idea of putting shovelhead jugs on my motor when I rebuild it. Anyone have any experience with this? What are the advantages and disadvantages? I want to build a bigbore engine to increase torque without sacrificing it's high rev ability as strokers do. I am also thinking of high compression pistons and a large oil cooler with a high volume oil pump to drive it.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
Larry "Skjold" Brink
1975 XLCH 1000
2006 VRSCA
Old 05-13-2007, 08:25 PM
pococj's Avatar
pococj pococj is offline
Default RE: Shovester
Lotsa machine work necessary to the Sporty bottom, and to the Shovel heads. Special cams, rocker arms, and I forget what all else. It's an awful lot of work, and an awful lot of money, for not really any more return than from a big bore Sporty engine.
If'n the bug is chewin' and making you itch, try scratchin' it with one of the S&S Sporty motors. They uselate model cases already fitted out for up to about 90 inches.
__________________
Brotherhood of Warriors Veterans Motorcycle Club
WFFW
BGBB Support Member
Old 05-13-2007, 08:46 PM
pococj's Avatar
Did a little digging. You might try contacting Trock. I don't have a link, so you'll need to do a search. The cases - cylinder deck area - have to be built up with weld so the wider Shovel cylinder bases will mate up. Cylinder bolt holes in the cases have to be welded up/redrilled, too. Don't know if just the cases,just the cylinder bases, or both have to be redone. Since Shovel push rod angles are way different than the XL the rocker boxes have to be machined to accept the new angle and seal up. You can still use stock XL cams, and the stock XL tappets, and the stock FL rocker arms. Not sure about the pushrods as it will depend on the height change from the lifter block/tappets to the rocker arms. Some work has to be done on the cylinder fins to clear the push rod tubes, too. And don't forget the custom exhaust that'll need fabbed up.
Lotsa expense any way you look at it. They do look cool!
__________________
WFFW
BGBB Support Member
Old 05-14-2007, 03:38 PM
83XLX's Avatar
83XLX 83XLX is offline
Senior Rider
1983 Harley Davidson Sportster
Trock Cycles are the experts. Here's an old poster.
http://i28.photobucket.com/albums/c2...2/Shovster.jpg
__________________
If it ain't broke, don't fix it.
Tags
build, cylinder, davidson, engine, harley, jugs, panhead, parts, sale, shovelhead, shovester, shovesters, shovster, trock, trockcyclescom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
