View Full Version : Ironhead
Pages : [1] 2 3 4 5 6 7 8
  1. bobber project bike (HELP)
  2. New project.
  3. Selling the '79
  4. Frame/Engine Numbers
  5. Bottom Dead Center?
  6. S&S Super E
  7. oil line replacement
  8. Thanks to the Admin!!!
  9. Ironhead pr0n
  10. Thread/ThreadStarter too w i d e
  11. rear pegs
  12. Almost There
  13. hot wing glass, seat
  14. coil wires
  15. Bleeding w/ DOT3
  16. rocker arm cover to crankcase oil line
  17. Bed time for the season
  18. Desperately in need of Guidance
  19. carb pop
  20. BackFiring Help
  21. Voltage Regulator
  22. thank you iron mick!
  23. flasher wiring
  24. leaking exhaust fix
  25. Pics of the 76 liberty edition...
  26. turn signal flasher
  27. ignition wire routing
  28. new try@ posting pics
  29. 1958 dry clutch
  30. new paint and decals
  31. hardtail frame?
  32. Tillotson carb number 66 sportster
  33. ron trock passing
  34. starter
  35. tapered bead tires
  36. finding a trustworthy iron head mechanic
  37. Xlh or xlch
  38. starter drag
  39. Primary drive inspection, clue requested
  40. '73 Charging system problem
  41. I'm getting close y'all
  42. what's this mean???
  43. Low compression, worn primary: ride, or not?
  44. Timing lobe shape
  45. removing lifter bolts
  46. ironhead belt drive conversion?
  47. anyone needs used parts?
  48. 72 sportster $
  49. 21 inch wheel?
  50. fork oil specs
  51. 1960 XLCH timing
  52. '79 Sportster start up question...
  53. Complete electrical
  54. Piniongear has no more questions or complaints...
  55. Piniongear has a question and a complaint.....
  56. cam cover gasket leak
  57. 1975 XLCH - to buy or not?
  58. engine compression
  59. Manual Spark Advance/Retard questions
  60. oil pressure
  61. S&S Super E-98Glider
  62. 76 ironhead
  63. key blanks
  64. piston / cams 85 XLCH ?
  65. What motors can go in a 1972 sportster
  66. 1970 push rods leaking
  67. new 79 home
  68. new to me 79 sporty
  69. Riser Bushings
  70. 1976 sportster question...
  71. Hi volume oil pump
  72. iron head chain get tight and loose
  73. a few more pics
  74. few pics of a bike rally
  75. 74 hardtail project bike
  76. 81 charging system problem
  77. Lotsa pressure
  78. Early/late 75 xlh?
  79. Rewiring a 74 Sporty
  80. Engine Oil in Primary
  81. More stupid questions!!!!!!!!!!!!!!!!
  82. Drive sprocket
  83. lost compression
  84. Won't start
  85. Ironhead with FL shocks?
  86. Chrome voltage relay cover
  87. question about brake master cylinder banjo fitting
  88. Need Input
  89. Almost finished . . .
  90. 81 missfire
  91. Flat track action
  92. Re-installing a starter on my Iron
  93. '65 xlch trans issue...
  94. rear wheel adjustment
  95. 1977 charging system not charging battery
  96. Need help ID pistons
  97. Carb and throttle
  98. honing top tree
  99. exhaust leak
  100. 72 Cylinders and heads.
  101. fishtail exhaust
  102. 76 ironhead starter trouble
  103. noise after warm up
  104. 77 XLCH will not turn over!
  105. Ironhead parts for sale !!!!
  106. ironhead cylinder heads?
  107. stuck in gear
  108. Insurance
  109. Ironhead years needed
  110. 81 started Kinda??
  111. 80 xls
  112. carb issues
  113. Mick Got Ran Into ...
  114. oil fill tank
  115. picked up my sporster last night
  116. pics of my 80 iroinhead
  117. new controls on an old bike
  118. 76 won't start
  119. regulator
  120. cam shim/bushing question
  121. ironhead temp
  122. Those arent points?
  123. primary chain adjustment
  124. metal trace in primary
  125. Primary chain/adjuster shoe life
  126. single wire generater
  127. 71 ironhead oil change
  128. What is everyone's opinion of this bike?
  129. My first Harley
  130. first ironhead,need help
  131. I think I'm stupid
  132. just need an opinion
  133. chance for a trade need opinion
  134. Clutch
  135. 75 tranny/73 block?
  136. Just picked up my 80
  137. Diagram of 1973 Ironhead Tranny
  138. Steel clutch plate slot alignment
  139. '74 Sportster kicker
  140. OFFTOPIC but must seen...
  141. new to Ironhead riding
  142. 74 Sportster Carb Problem
  143. new to me sporty
  144. Clutch hub and main shaft bearings
  145. Spark plugs
  146. Any experienced shops in GA/Southeast for Ironheads?
  147. Clutch hub nut removal
  148. sprocket ratio
  149. gererator noise
  150. Primary breather valve elimination?
  151. Timing question.
  152. Mikuni VM38 trouble
  153. Ironhead oil pump
  154. Oil Filter For 1972 XLCH ?
  155. Shocks
  156. Gettin' close
  157. my wifes 72 Sportster build.
  158. pain in leg
  159. Help stop the Brake Rattle!!!
  160. do I need to use a horn relay?
  161. 72 XLCH sportster oil leak
  162. anyone familar with different rotors...???
  163. Gear shifter issue - '72 XLH
  164. chain oiler bypass suggestions
  165. Even mo' progress
  166. Mo' progress
  167. Ironhead oil line?????
  168. push rod adjustment
  169. ironhead to shovel conversion
  170. Figured Out What Snapped!
  171. japanese forks on an ironhead
  172. can anyone explain the #s on the neck ?????
  173. starter sylinoid
  174. 75 xlch. why does the generator light come on all the time.
  175. Rim Material
  176. compression
  177. Something Snapped?
  178. Project progress
  179. 1977 1000 sporty
  180. Timing on a 73 ironhead
  181. What ignition system in a 1972 sportster
  182. 1973 xlh
  183. 1972 ironhead FLCH right side shift leaking oil
  184. 75 Ironhead clutch slipping
  185. Check out my 78
  186. super gorgeous ironhead
  187. branch intake
  188. Tenino Antique Motorcycle Swapmeet Aug 15 & 16
  189. primary chain
  190. paint in gas tank
  191. Cylinders, Combustion Area and Carbon/Soot.
  192. Ironhead charging issues
  193. 76 ironhead (pinging)
  194. generator to alternator
  195. alternator noise
  196. lost compression and white smoke!
  197. Stubborn Starting
  198. newest motor in a 68
  199. 76 ironhead starter trouble
  200. 71 xlch that won't shift
  201. gas flow problems
  202. 75 Ironhead chain oiler
  203. 75 Ironhead fuel octane?
  204. Need Machine shop recomendation for valve seats
  205. oppinions please
  206. Spark Plugs
  207. primary cover
  208. What is the difference in 1000 Sportster Heads & Cylinders?
  209. keihin cv
  210. s&s super B jeting
  211. clunking noise in 76 sportster
  212. '80 XLS brake line question
  213. 74 XL Oil Leak at Push Rod Cover/Tappet guide
  214. 75 Ironhead clutch drag
  215. 76 Sorty timing gears pic
  216. Going Rigid???
  217. thru bar wires
  218. 4th gear slippage
  219. Electronic ignition?
  220. 75 Ironhead oil bag functions?
  221. New here, looking to make some friends. I need some help with an 82 xlh 1000.
  222. What's Considered Normal?
  223. Early vs. Late
  224. whats going on
  225. WTB hardtail frame for 1980 Ironhead motor
  226. 4 speed to a 5 speed
  227. intake / exhaust leaks
  228. '82 clutch dragging
  229. 1982 sportster generator ????
  230. xlh and xlch whats the difference
  231. 78 sportster electric start problems
  232. Cam chest assembling questions '80 XLS
  233. Fuel type for 1980 Sportster
  234. 73 XLH - Several fuel related questions..
  235. runnin hot!
  236. forward control problems
  237. Caliper for 83 XLX
  238. 75 Ironhead solenoid/starter problems
  239. progress update
  240. primary fluid question?
  241. Cam Mess
  242. 67 xlch rocker arms
  243. XL rocker arm screws
  244. Ironhead generator testing questions
  245. Rear fender strut interchange
  246. 59 XLH rebuild help.
  247. 900crank set in 1000cases with 900 barrels/pistons and top end can this be done??
  248. 1974 XLCH Sprocket Shaft Bearing spacer
  249. Shakin' baby Shakin'
  250. Its alive
