View Full Version : Panhead
  1. vin numbers
  2. timing problems
  3. saddlebag Locks 63-69
  4. gas tank problems
  5. 48 panhead
  6. 1963 Panhead Camshaft
  7. This bike just changed my world!
  8. Panhead distributor
  9. Value of 58 Duo Glide
  10. 1964 Period Chopper,kewl
  11. Synthetic oil
  12. Excessive chain oiling
  13. Help with timer & oil pump
  14. 64 pan vin
  15. Generator or Regulator?
  16. pan questions
  17. NO Pics
  18. 52 Pahead in 70s chopper trim FS
  19. Pan cylinder, need info
  20. 61 FL help
  21. Ballpark figure?
  22. 53 pan assembly
  23. need help wiring
  24. Valve cover removal
  25. 50 Panhead & 77 FLH
  26. 49-53 Type 2 Handlebar Pull Spiral
  27. what year is this trann???
  28. 53 oem uncut rigid frame.
  29. 1949 paint code needed
  30. 1960 12volt conversion
  31. S&S pan kick starting problem
  32. Electric Frank wiring
  33. blown head gasket
  34. head gasket leak
  35. Idea on value of a '57 pan?
  36. Do any of you still ride your Pans regularly?
  37. crasha51pan
  38. Valve job
  39. Got a 1960 pan puttin' it in a frame and
  40. 1950 PanHead TT
  41. Looking For Advice
  42. advice on interchangability
  43. need 59 FLH wiring diagram with signal lites
  44. 59 pan ub question
  45. My '59 FLH rebuild (not restoration).....
  46. Lef side crankcase seal 1952 pan..
  47. electrical problems
  48. Panhead "s
  49. having problems with ss oil pump on my 49 panhead
  50. Dad rode Panheads
  51. 1951
  52. 52 flh
  53. 61 fl pan
  54. Dual coil cover
  55. Mikuni flange
  56. getting a single disk on an early Pan wheel?
  57. Runnig Good !!!!!
  58. Pan Head generator ???????
  59. It Started !!!!
  60. It Won't start
  61. Pan head reserve valve alignment
  62. 53 Panhead primary question
  63. head cover gasket???
  64. Oil pump
  65. Motor rebuilds
  66. New Oilpump. Advice?
  67. long haul on panhead.Advice?
  68. new 53 Pan/shovel owner
  69. M74B Linkert Carb
  70. test ride
  71. 1962 panhead flh ( SOLD)
  72. '62 Pan Coughing & Choking at stop signs/lights ... HELP!
  73. Oil coming out of front exhuast?
  74. panhead stroker pistons
  75. help on a pan $$$$
  76. Front drum drag
  77. pan points
  78. how much for heads
  79. generator conversion
  80. Panhead Project??
  81. fork legs/sliders
  82. 2 right side flywheels?
  83. Safe and Sound
  84. Dying to get a 48 Pan....
  85. To magneto or not?
  86. torque requirments
  87. OEM HD brake - clutch pedal pads
  88. solid state regulator
  89. whats idle on 65 pan with 86in and s&s
  90. looking for a wishbone frame
  91. super e problems
  92. panhead carb/cam
  93. mouse trap clutches
  94. WANTED A PANHEAD
  95. 1950 panhead tappet adjustment q
  96. Q for the Panhead experts
  97. Looking for a side shifter p/h gas tank?
  98. no start 56 panhead
  99. electric start for '55 pan
  100. 6 volt bulbs/sealed beam units
  101. Unleaded gas in a panhead?
  102. STROKE OR NOT TO STROKE
  103. Panhead gas tank question #2
  104. How to interpret engine part #'s
  105. 48 pan upgrades, charging, brakes, starter
  106. Thoughts on a replica Panhead
  107. Panhead gas tanks
  108. I need help starting my pan!
  109. rare build
  110. I'm impressed
  111. How do I adjust my primary chain?
  112. Good service manuals for Panhead's
  113. Interested in Panheads
  114. Kickstarting hints please!
  115. magneto problem
  116. Hydraglide wiring question
  117. Emblem
  118. 51 panhead
  119. panhead big bore head gasket
  120. Viet Vet Pan
  121. Dual point VS single?
  122. panhead
  123. 1952 HD Panhead for sale!
  124. Hard to come by parts
  125. Speedo restoration
  126. pan case
  127. tranny numbers?
  128. Panhead/Shovelhead Frame ID
  129. Intake pushrods - to long!!!
  130. troubleshooting
  131. location of serial number on frame
  132. I am now the new owner of a ...
  133. Panhead heads - tightening
  134. oil blowing everywhere
  135. How similar to shovel? 1951 Pan
  136. oil leak
  137. Super E on a pan?
  138. Front terminal board - Springer PH
  139. Bars
  140. have frame need heart
  141. Mouse Trap Adjustments
  142. Fuel shut off mechanism for '59 fat bob tanks
  143. panhead breather valve
  144. 63 Pan wont start
  145. Anyone know where I can get a tank shifter/linkage?
  146. "Old school" custom panhead
  147. Rockers no lubrication
  148. lifter blocks
  149. question about vin designations
  150. I love my old girl
  151. Did '64 have unique "4" in VIN
  152. FS - 1957 Panhead Bottom End
  153. Soquel Vintage Motorcycle Show 7/1/07
  154. My 64 is Finally Done
  155. Passenger Pegs for '61?
  156. MouseTrap problem
  157. Electric start vs. Kicker
  158. need help with 64/74 pan shovel
  159. Horn Question on a 65 Pan
  160. Fair price for a 1965 FLH
  161. very low oil pressure
  162. oil pump removal.
  163. Brake line replacement
  164. oil problem on 65 Electraglide
  165. Spot Light Lights for a '61?
  166. 64 PAN CARB Problems
  167. Light bulb for Guide 2025-A??????????
  168. breather valves in top fork capbolts 49-77
  169. Need to send out my 49 motor for a rebuild
  170. '56 Panhead Rebirth
  171. 1957 pan chopper
  172. bad kicker
  173. connecting rod slop
  174. the TAMER
  175. junky bike
  176. 6 Volt Battery?
  177. anyone seen a hub-cap like this on 61 pan?
  178. HELO ON A 51 CLUTCH AND PRIMARY BELT
  179. 1957 FLH All Original
  180. 61' Fork Question
  181. Am I crazy for wanting an old Panhead?
  182. Whats it worth? 51 pan head
  183. wishbone frame
  184. Engine main seal?
  185. Tranny Shop
  186. I'm new with bikes and I just got a 62 Panhead
  187. [Deleted]
  188. rebuilding my 1962 panhead
  189. 2007
  190. Shift Gate
  191. 65 Service Trike
  192. Tranny main seal?????
  193. Honestly need help guys.....
  194. help with name of 1950's lights, please
  195. A photo of a 1948 Panhead.....enjoy
  196. Newbe
  197. Wanted- engine cases
  198. Starting 55 Panhead
  199. 64 panhead insight
  200. Gravity?
  201. three pans and ariel
  202. 65 Original Paint Pan
  203. Panhead Rocker Arms
  204. NEED INSIGHT ON '54 PAN
  205. My friend's '52 Panhead-For sale.
  206. my brother's 52 pan
  207. 65 Pan setting points and timing
  208. Fork Question
  209. Worsham Castle Cycle Leather
  210. What year is my trans?
  211. 1948 lifter blocks
  212. 4 speed mainshaft
  213. 4 speed trans.
  214. DMV title problem
  215. OEM Tank Emblems
  216. 65 Panhead Information
  217. Restoration for tank emblems
  218. What's a good cam for a 1961 big-twin?
  219. Gas price's
  220. 47 panhead
  221. Spotlamp Repair
  222. titles
  223. Update
  224. The Saga Continues
  225. What do the switches do?
  226. How do I start it?
  227. 12 volt gen.
  228. Bogus VIN#
  229. VIN #'s on '61 Pan
  230. Crazy thought
  231. panhead rocker arms
  232. 61 panhead value not being orignal
