- Crankpin torque
- ignition
- 1978 flh
- 67 FLH issues
- 63-69 saddle bag latch
- shocks
- More Blonde Questions...
- Going Rigid.. What do I need?
- Clutch adjustment 1980 flh classic
- New style Forks in an 80 FLT's trees???
- Oil on spark plugs
- Help with tranny oil capacity.
- question
- Timing problem
- What are????
- 74" with 80" jugs
- 78 FLH won't stay running.
- suicide shift
- 82 Superglide!
- front sprocket, recess in or out?
- 1976 shovel 4 speed
- '79 1/2 Lowrider
- Excitment
- starter problems
- 76 super glide
- Temp diff between front and rear Cyl
- 86 shovel S7S super B?
- Just bought my first shovel - 1983 FXDG
- Wrecked 82 shovelhead
- Why do shovels always need a top end?
- sprocket
- 78 fxe inner primary
- 1978 1/2 FLH Parts manual or CD
- Runaway Starter
- clutch rattle
- wanted: exploded view of lifter
- Just Got 'er Done
- FXE Shovel Head Shakes?
- carb tunning help!please!!!
- cv carb float adjustment
- FL to FX battery switch...
- Controls and floorboards
- Oil Breather tube
- 1975 Super Glide HELP!!!!
- My '75 shovel
- circuit breaker
- I'm getting a shovelhead!
- 76 FLH questions
- FLHT fuse box
- 69 shovel ignition point eliminator
- 79 Shovel Help
- Electric start problem
- Low fuel in filter
- 73 shovel somebody please help me
- tach jumping
- trans oil
- 1977 fx i need a wiring digram
- The Bride of FrankenBike Returns...
- 1980 mfxs swing arm
- 1983 fxr transmission top cover oil leak
- fork oil capacity
- Clutch noise
- New front end old front wheel
- need some advise please
- newbie-what to check when buying
- Quagmire...kinda long
- changing fork seals on a 1974 fxe
- What model is it?
- FLT Tour Glide cruising speed
- Primary Chain length ?s
- rod bushings
- How the heck do I get my trans out of my 72 FLH?
- Wiring harness
- 79 fxe ignition timming module blown
- Best under $100 modification for me yet!
- Shovelheads, high maintance???
- Shovelhead clutch
- 1984 Shovelution....
- Front end question
- Advice needed Please.
- 1980 flh 80
- Police special
- 1975 Paint Formula Needed - Help the new guy...!
- cowpie or rachet top
- How much oil, and what weight
- 73 shovel droppinf front cylinder
- Lifting gas tank
- Salvage Nightmare...
- 80 flt blow buy
- 80 flt blow buy
- FXS 78 - Highway Pegs
- s&s carb on shovelhead
- exhaust studs or bolts
- Red Saddle Bags....
- To Buy or To Repair...that is the Question!
- carb issues
- Thanks to everyone who recommended Monster Ovals!
- 81 fxwg info needed
- recognize this oil filter/cooler?
- What should I look for?
- 78 fxe compensating sprocket nut
- oil puking thru crankcase breather?
- Harley Davidson Exhaust. (SLIP ON)
- 78 fxs
- ?what carb is this
- carry over / wet sump ??
- '82 flh backfiring
- Cylinder 1 Popping out of carb under idle...suggestions?
- engine oil temp...'80 FLH
- Compression 125 Front, 0 Rear. Just Rebuilt. Please Help.
- Rocker shaft end cap bolts, and various other oil leaks.
- 73 spotster generator problems... help!!!
- Last 1984>First 1985 Shovelheads
- Will 91-up hypercharger fit on my shovelhead?
- Showa 35mm fork seals leaking
- 73 shovel kicker only dont want to start
- How to price a 1969 shovel
- 78 Shovelhead Trans leaks
- Recommendations please!!
- Tire size
- Please help me fix my shovel
- 77 Super Glide Won't Run When Hot
- FLHT seat
- Saving Money
- Wanted !!!
- starting issues
- intake manifold
- I cant sell my shovel
- engine clunk, front cylinder
- Info apprciated
- Running, Rode It, Not Running, Issues...
- s&s 80 shovel carb info
- transmission oil level
- big twin timing trick
- 1978 shovel 1340
- 6 pole ingnition switch.
- not on my OLD scoot!
- what the F@#k!!! S&S super E
- Shovelhead cone left case
- Newbie buying a Old 80 Shovel FXE
- 85 sportster rear wheel
- lost oil pressure
- back brake light switch mount???
- HD Shovel crankcase part numbers, anyone?
- 73 shovelhead hard starting
- Question about an old FLH shovelhead
- need more light
- 1973 Shovel Electronic Ignitian Conversion
- 82 fx neutral light
- 28 FXWG starter
- 80" flywheels/74" pistons
- Gas in oil
- 1980 Shovel misfire.
- 79 Shovel Electical Bug
- shovelhead starter drive
- need transmission
- question on 2 into 1 pipe.
- primary chaincase vacuum
- Oil cap broken?
- Keihin float bowl gasket issues
- shovel head mileage
- More Shovelhead
- Questions for pococj
- ok this may be a dumb question....
- 82 fxr, and I have a few questions...
- Help...Questions about my 1983 FLHT
- trani
- need special tap
- Oil/Filter questions
- new shovelhead-- acutally first ever harely
- 81 FLH clutch handle
- First rebuild
- Oil pressure gauge
- 67 FL info
- Picked up a flyscreen...
- Speedometer drive for rear wheel??
- 1980 shovelhead misses at idle
- Keihin rebuild kit - who makes a good one?
- what kind of carb do i have
- '82 FXE for sale
- some bikes and a Liberty build.
- 79 Shovel Electrical Problem
- 79 Shovel Crankcase breather pugged off???
- clutch pressure plate angle
- poping thru carb
- carb bracket
- Help with Dyna 200i-p install
- wont start...throttle dont work...crap
- rocker box chrome line kit V-Twin 40-0180
- Need advice please
- Exhaust Bolts
- Exhaust gasket
- shovelhead rubbermount question
- Same old shovelhead primary question
- what kind of gaskets?
- Police air seat on my Shovel.
- 4 Speed Trans question
- 84 FXSB neck angle
- Found a small weld on crankcase????
- new build
- Only one cylinder working???
- Transmission Whining
- Kicker Issues
- shovelhead carb question
- where is everyone?
- shovel head starter problem or solanoid
- shovelhead exhaust issues
- Looking to buy shovelhead
- Exhaust power cones
- 79 fxe front end question
- Will a Corbin Solo Seat for FL fit an FLH
- Crane Cams...Out of business :{
- Solid lifters
- Hard Starting 82FXR
- 1973 Shovelhead
- rewiring a 73 FLH
- Kick starter is not engaging - what to do?
- Lean Angle?
- Swap Meet, Humble TX
- sneezing shovel
- Encased final drive chain
- Carb suggestions for a '66 shovel?
- NO Compresion in cylinders...
- shovelhead pushrod cover leak
- 83 FLHT front springs and rear shocks question
- Shovel identification help
- manual to hydraulic clutch- 4speed
- Later model wheels on an '81 FLT
- chain primary
- Customizing my 83 FLHT
- Want it lower...
- need help...my first top end rebuild
- Power
- 1980 fxwg
- a problem with shocks/studs fitting
- 1980 5 speed
- 1966 FLH Restoration Project
- 80 FXS grinding problem.
- 1980 Wide Glide
- Front fender... yes or no
- Frame tab...
- Pix of your shovels....
- Looking for original '82 FXE exhaust.
- shifter problems
- to too many shovelhead threads i see
- Lifter block won't come off!!
- Anyone running LePera Bare Bones seat...
- Tips on Shovel Intake Manifolds
- How Much Oil Does a Shovel Use?
