View Full Version : Electrical/Ignition/Tuner/ECM/Fuel Injection
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Ignition lock cylinder release button stuck.
  2. Speedo Pin Out
  3. intermitent electrical fault
  4. Restart after tip
  5. fuel injection
  6. Wire diagram for ignition module32405-91A
  7. 2006 Eating Batterys
  8. PIAA H3/Lighting issue with my Softail
  9. Multilock Crimp tool
  10. Adding fuses ?
  11. Security Key Light sync with Speedometer Light?
  12. Reverse polarity connection of battery charger
  13. Have Power Commander 5 for Softail - will it work for Dyna?
  14. 2007 Sportster 883 not functioning
  15. Where is turn signal module in 99 Ultra?
  16. TTS and dyno?
  17. buss er fault
  18. cruise problem
  19. 6th Gear Light and Tmax
  20. I am going to steal a Harley tomorrow!
  21. Where is start relay on 99 Ultra fuel injected?
  22. carb guy going EFI, 3 Questions
  23. stalling problems
  24. TTS Master Tune S. Florida Help
  25. Restarting an EFI bike after emptying/removing tank
  26. How to convert mechanical speedometer to electronic?
  27. 4 EGA Tuning vs A/F ratio Tuning
  28. Fatboy rear turn signal wiring harness is there a part #
  29. '96 dyna wide glide speedo
  30. 07 Ultra Idle
  31. V&H fuelpak with Rinehart TD's?
  32. Problems with SE Stage IV kit/58mm Throttle body
  33. 07 Street Bob misfires
  34. which calibration file for TTS Mastertune
  35. Low RPM misfire-cough
  36. Help
  37. Help needed: Fuel management modules for Cross Bones
  38. to plug or not to plug 02 sensor
  39. code appears on my odometer
  40. LED stop/taillight
  41. main bat. circuit breaker problems
  42. Where is the TSM on a 2000 Ultra????
  43. ECM allen head Bolts
  44. Good dyno/tuner in Kansas City area
  45. VE set at 13.2:1 WHY
  46. Wiring issue
  47. 2007 Electra Glide Dies when cold
  48. Where best place to get TTS Mastertune?
  49. Running light not working
  50. FEET HURT 2001 Roadking Classic EFI(Low to No Spark)
  51. Sportster 1200XLC will not start when its hot outside
  52. Speedo sensors (VSS)
  53. How To Remove The Battery - FLHX
  54. Speakers on FLHTCI 2003
  55. Auxilary Lights/Passing Lamps
  56. Fuel pressure regulator question
  57. Security light/no speedo/no blinkers
  58. Tuner/EFI options?
  59. Where is check engine light on 99 Ultra?
  60. Need help installing rear turn signals
  61. Blinker issue
  62. Turn Signal Problem
  63. Oil pressure gauge pegged
  64. Help please no spark
  65. one SERT cable lost
  66. Handlebar Switches stop working
  67. Tuning SERT for better gas mileage?
  68. fair price...
  69. Tuning a Edelbrock RPM performance Kit
  70. 04 FLHRCI DTC Troubleshooting help
  71. Help With Dynatek Curvemaker Please
  72. Tail Lights out
  73. New battery, what make/type is THE best??? (and how do I stay away from the Vette???)
  74. Throttle by Wire
  75. Updated software for TMax
  76. Electrical Help with my 2002 Dyna Lowrider
  77. help with ignition module
  78. EFI Enrichment Device
  79. "Engine" light comes back on after start
  80. Need input- ECM ?
  81. U1097 Loss of Speedometer Serial Data. What does it mean?
  82. 2005 Sportster 1200C Tachometer
  83. TTS & VE tables
  84. Battery tender wiring
  85. European radio frequency for FLHTCI 2003
  86. Clutch starter interlock
  87. Questions on Kuryakyn Panecea lights
  88. Turn signals not flashing?
  89. How do I get rid of my TSSM
  90. PC-V map with cams..
  91. Problem with bike and security system
  92. Thunder Heart's stand alone ignition system.
  93. Help with 04 FB
  94. HELP! My 02 RK has a ghost.
  95. Stage 2 with SERT to be installed, Advise?
  96. Starter problems.
  97. Deutch connector access
  98. 97 flhtcui no running lights
  99. Hard start in cold
  100. '08 Nightster Bus Err... HELP!
  101. Fed up with EFI.
  102. 08 streetglide turning off
  103. Possible electrical problem - please help
  104. spot switch
  105. 2008 Streetglide Fuel injection management upgrade
  106. Starter Motor 101
  107. Black Smoke from exhaust on cold start
  108. Feul managment
  109. Check Engine Light on 2000 Dyna Low
  110. Live In Alabama
  111. 1995-1999 Dyna wiring diagram
  112. Very strange electrical problem.
  113. Zippers Thundermax with Autotune
  114. 2005 Sportster 1200C Tachometer
  115. Do I need a Tuner?
  116. Wiring diagram for 91 flhtcu
  117. Power Commander or SE Race Tuner
  118. 95 wide glide starter dead
  119. help** tbw ape bar question
  120. Do EFI engines have O2 sensors?
  121. Is HD Stage 1 download, generic?
  122. Fuel Pak Settings with RSD Velocity Stack ?
  123. Start switch won't work
  124. Hidden Ignition switch
  125. Have SERT, thinking PC-V now
  126. PCIII Closed Throttle Values
  127. 00 fxst cuts out
  128. FuelPak & Samson True Duals synch issues
  129. Tuning help please 2010 FLHR
  130. PCIII map for SE204 cams
  131. 6 volt battery needed
  132. Maintenance 101 Question - use for impact wrench?
  133. electrical issue
  134. Exhaust Still Popping After A Dyno
  135. loose light bulbs
  136. SEST cranking fuel
  137. Magnelli Injection hard start
  138. Another...Mystery Engine Shut Down
  139. What brand Stator do you guys recommend for`94 Fatboy?
  140. Mystery Engine Shut Down
  141. power commander with autotune?
  142. Swapping headlights on an 09 Fat Bob
  143. Is the TTS server down?
  144. Running Lights
  145. TTS mastertune question
  146. Turn signal issues
  147. Turn signals flash when ignition is turned on
  148. Cough & Backfire
  149. Waterproofing Electrical Wiring
  150. popping and skipping
  151. map help
  152. power comander V
  153. quick question about XIEDs
  154. Request: Edited Thundermax Map - 07 dyna - rineheart 2 into 1
  155. Voltage Regulator gone bad??
  156. 08' Ultra with electrical problems
  157. 1988 softtail loosing front spark
  158. almost taken out
  159. tach for 08 heritage
  160. No start, No turnover, No nuthin
  161. No Turn Signals
  162. 1991 electronic flasher problem
  163. Looking for Fuel Injectors Wiring Diagram for 2003 Roadking
  164. speedo,tach.turn signals,brake lights don't work
  165. Question about tach signal from ECU
  166. Electronic throttle cuts out
  167. Simple wiring diagram
  168. power commander 5
  169. TTS tuner file needed
  170. Help
  171. 89 sportster 1200 blinker/running light issue
  172. Sportster Electrical Starting Issue
  173. ignition switch replacement
  174. code retrieval procedure
  175. Installed apes now now low beam
  176. PC-V Map = Hooker troublemakers, Se stage I
  177. Searching photos of 2010 O2 sensor plugs
  178. Ignition coil/module twin cam FI
  179. Headlamp/Passing Lamps go out intermittently
  180. Bulb cross reference
  181. 2000 FLHRI cannot start, no engine light????
  182. Need some Help
  183. My plugs after the Fuel Pak
  184. how to tell if 07 Roadking has factory alarm
  185. 08 rocker fuelpak settings
  186. SE 103 ci Kit & SEST - can I get by without Dyno tuning?
  187. Removing Gas Tank 2009 ultra
  188. installing factory heated grips 2009 ultra
  189. Electrical Problem
  190. Windows Vista 64 bit & Tuner Software Problem
  191. Slow starting after installing the PCV
  192. Latus H-D for Dyno tuning - your feedback?
  193. Switching superglide ignition and speedometer
  194. Pc #812-511...
  195. Can't find the breaker!
  196. SERT, SEST, TTS, PC-III, PC-V, etc. what's the scoop
  197. Anyone with an Autotune system...
  198. Motor Dies when cruising
  199. rotor on charge system shears bolts
  200. 1999 and 2004 speedometer difference? Pls help.
  201. thundermax software and vista
  202. idle issue?!?
  203. PCV software/map question
  204. hestitate in bike
  205. Hey all took my front turn singals off, now check engine light on... HELP
  206. SF Bay Area ThunderMax tuner?
  207. How to hook up to accessory plug on '07 Dyna?
  208. Unplugged 02 Sensor
  209. Electrical Mystery
  210. Parking (running) light keeps blowing out
  211. Fuel Pak question
  212. PC V map/questions
  213. Bike bogs on Up shift/Rapid Acceleration...?
  214. SEST Tuning
  215. home tuning???
  216. Stage 1 or Heavy Breather?
  217. Taillight woes!
  218. NEED HELP GUYS. 09 Road Glide- Ignition switch was turned too far....
  219. Voltage regulators
  220. ECM Tuners
  221. HELP Wireing diagram for a 2009 fatboy
  222. Biketronics stereo
  223. cams
  224. SERT question
  225. error message showin
  226. Speed sensor for 6 speed evo trany
  227. ocassional cylinder quits firing
  228. I want to install LED blinkers without a load equlizer... Will a electronic flasher??
  229. Thundermax- installing modified map
  230. '08 Ultra, lost FOB/key, on the road, stuck!!!
  231. Electrical problem
  232. Bad Ignition Switch?
  233. Engine light??
  234. 2010 touring O2 sensor bypass
  235. 1996 harley dyna ignition problem
  236. EFI Fuel Pump Question....
  237. Ignition trouble while on the road.
  238. fuel gauge
  239. The problem with the rear turn signals
  240. 2009 street glide run hot ??
  241. 2007 Road Glide fowling plugs and lost spark on a trip now..
  242. Tuned Fuel Consumption ?'s
  243. Vance and Hines Fuel Pak Codes
  244. 04 Softail Electrical Gremlin?
  245. 07 bdeluxe running light conv. ....Brake Lights On all the time
  246. Magneti-Marelli Fuel Pressure Tweaking?
  247. 78 Low Rider cutting out at 70 mpg
  248. 2004 sportster won't start
  249. Radio Ground Issue? - Please Help!
  250. handlebar controls with aftermarket radio on RG?
