- replace clutch
- clutch adjustment
- Oil stain
- Cometic Seals
- A good replacement clutch kit
- 2006 Street Glide Engine or chain area noise
- drive belt at 20K
- Getting into first on my 5 speed
- Shift Shaft Seal.
- 06 Street Glide grinds when downshifting to 1st
- Trouble downshifting @ a stop
- What other seals to replace
- Newbie Primary Advice
- Stock clutch life?
- TC88/5sp Tranny Fluid Change
- help i'm confused
- transmission main drive gear bearing failure
- Clutch won't work
- Some trouble downshifting. Please help.
- Clutch Adjustment
- chain conversion for 09 RG
- need help with primary leak
- Weird Noise Help
- Clutch Removing/Installation
- Replacing drive belt
- Is it the transmission?
- on/off grinding Noise in front primary
- Draining Tranny fluid on softail ?
- Andrews 30 tooth Tranny Sprocket Belt Replacement
- Energy One Clutches
- Chaincase cover (derby cover) gasket
- Help with tranny oil level.
- 01 electra glide c
- 07 rk tranny issues
- Can't find neutral?
- Belt tensioner. Question.
- Has anyone broken a 6 Speed??
- Trans Vent leak
- Tranny fluid leaking down clutch cable
- Clutch cable
- Medium speed noise when I release the throttle or activate the clutch
- Show me your foot clutch
- 49 Tooth Evolution Industries Clutch Sprocket
- Broken drive belt
- 5th gear noise in 2009 FLSTC 6 speed tranny
- Police Bike Gearing
- 2000 Dyna - drive belt broke
- Flywheel & Compensator Shims for Primary Alignment
- Trans. fluid for 2010 FLHTK
- Shift Lever Shaft Bushings?
- Transmission main shaft nut tool
- Baker F6F 5th gear
- noisey tranny or chain 03 FLSTFI
- Tranny identification
- Clutch area noise HELP
- Newbie needs some help here...
- Wedge Tensioner Has Arrived
- 2004 road king custom shifter
- 95 xl 883 won't shift when warm
- Carbon vs Kevlar
- Baker High Torque Primary Bearing.
- ATF in primary??? What makes you choose one ATF over another??
- Sprocket Seal Oil Leak?
- Is HD Clutch Spring Essential on Stage II?
- Comments welcome
- 01fxdwg
- Whats gone missing?
- 1996 FLHTC Vibration
- Se compensator noise
- Clutch
- 1983 IronHead XL1000 Cam Cover
- Problem with the compensating sprocket
- Does not include 1 and 5 gear
- whistling from primary
- Starter drive noise?
- Leaking Primary 1985 FXST
- '06 Dyna Shifter Drum
- Stripped Primary Outer Cover Drain Threads! - How To Fix?
- elec.starter ???? 65-69--help
- Stripped Primary cover drain
- Clutch disaster
- 5th or 6th Gear Needle Bearing Walking
- Clutch and mystery noise from rear
- 1974 Z90 2-stroke gear case oil
- 07 RK compensator shot?
- 1979 xls question about sprockets
- tranny
- Wondering if clutch adj. needed only
- Drive belt ID?
- 5 gear making noise
- Need help with diagnosing noise
- Primary Housing Leak
- 06 DYNA owners IPB I might have your solution
- Pulley Nut Tool
- 06 streetbob inner primary bearing question
- Phat Performance Parts...
- Front Motor Seal Leak for 3rd time.
- 08 Ultra - clutch issue?
- Link to catastrophic tranny needle bearing failure 02 FLH SE RK!!
- checking tranny oil
- 1989 XLH 1200 neutral problem
- sportster clutch problem
- trouble shifting to 2nd when cold
- How to remove clutch and starter jackshaft bushing in inner primary on 2005 Road King
- Main Drive Shaft Oil Seal - Replacement Cost at Dealer?
- Clutch Choices
- Is this compensator chatter?
- Street Bob 06 Clutch Grinding
- Help!! Clutch won't fully disengage....
- SE Products Comparison
- 08 flstc trans drain plug
- CF2 Performance Clutch
- Simple Compensating Sprocket or bad flywheel
- 78 sporty road speed
- what do i need
- 07 ultra downshift and it drops 2 gears
- Install/Ride Report: SE Comp + Evo Ind 49T on 07 EG
- Clutch problem
- street bob clutch removal
- Neutral Switch Problem
- perplexed by my ignorance
- Inner Primary Bearing - 06 Street Bob
- Problem with my dad's Heritage
- clutch went out--why?
- 4 speed ratchet top shifting patern
- 95 Ultra clutch issues
- High pitch noice from either clutch or tranny
- Inner Primary Removal 1979 Shovelhead
- Not catching
- 2007 FLHX Clutch problem NEED HELP
- Whinning Noise In The Rear
- Sportster Transmission Clunk
- Tranny Not Engaging
- Fifth Gear
- Clutch Hub/ Drum Replacement / Oil Leak
- Tight spot in chain
- kicker shaft.
- Primary Fluid Question...
- Sticky Shifter Problem
- Drive belt sqeak
- Different Drive Belt
- hard to downshift after working on primary
- Stock starter can not hold up to a 3" belt drive
- Primary has sprung a leak
- Stock Clutch power limitations
- Primary Inspection Cover
- Help!!! Rattle noise
- 2009 5th Gear Clatter and 2010 Helical Cut 5th Gear
- Open HD chain drive on street bob????
- 07 fxstd rear wheel noise
- 76 Shovelhead FX
- Champion reverse gear assistance?
- 73 Ironhead Help
- Unusual knocking
- Shifting from First to Second
- Clutch, Transmission Troubles - Motor Trike conversion
- Neutral Light
- chatter/whine
- too much pony
- Belt to chain conversion.
- New clutch cable problem
- EVO Clutch question
- Lost Drive
- Blue or Red Locktite
- clutch snaprings
- changing fluids on my 2006 fxd superglide
- '99 Night Train - 10k mile service questions - DIY
- 96 Softail Compensator sprocket spring and cup
- help a guy find his leak? :( Pics included!
- Primary chain...too tight
- no trans oil!!! no leak!!! whats the deal?
- Kick start problem
- 84 evo flhtc clutch question
- GOOD GOD, what have I done...
- Transmission pulley swap
- Starter Noise Warning!
- 76 Harley FXE Shovelhead Dry Clutch
- Adjuster screw
- 2009 Road King Engine Trouble
- Primary Bearing Race....34091-06 or -08
- Leaking Primary on '09 Ultra
- Axle Nut Size?
- Trouble finding neutral..
- trouble engaging second gear
- Derby Cover Problem
- clutch won't engage
- Fisher Damper
- Clutch Help on a 96' Heritage.
- transmission bearing for a 6 speed gear set?
- Clutch plate replacement question
- Where to buy heim joints?
- clutch inspection cover
- Removing transmission sprocket nut - use torch?
- Clutch not working
- Tranny whine
- Transmission Fluid Leak - I don't know where
- 2000 sportster rattle
- Shifter Shaft oil seal (behind inner pri)
- Strange sound after switching to RL MTL
- 08 RKC Speed Sensor Oil Leak
- Teflon clutch cable?
- six speed swap
- shifter arm loose
- Re-use the red gasket?
- primary clutch or trans noise?
- belt to chain conversion
- FLHTC tranny leak input/output shaft oil seal
- pulley shaft seal
- clutch pack lock nut
- Bearing noise
- 75 shovel rocker clutch jockey shift Help!
- Replacing a drive belt on '06 Street Glide
- 2006 roadking trans fluid
- to change sprocket,transmission
- torq spec for the bolt that holds the heel toe shifters????
- Questions on removing clutch hub nut
- New Road king-Primary Noise?
- Sticky shift lever
- 2005 Sportster Clutch is Stiff/Tight
- 69 Iron Head clutch adjustment
- How in the H3ll did Harley get away with that!?!?
- screeching noise
- Compensator Carnage!
- Clutch Cable Adj Moving:
- barnet clutch tension
- Clutch Lever/Cable adjustment
- Clutch problems
- primo brute v on 07 fxst?
- Question on turning over engine by hand - with picture
- 1989 ultra clutch adjustments?
- Motor oil in the primary case?
- hydraulic clutch question
- Inner Primary leak.
- will it fit? pulley ???
- Clutch Cable replace ?
- Venting on the primary case?
- Final drive belt. Aftermarket or Harley?
- Switched to severe gear?????
- Has anyone upped from a 5 speed to 6 speed?
- Gear case bolt torque
- clutch hub play
- Need help....
- Automatic primary chain adjuster
- something musta broke??
- Extension Kit for Mid Controls
- slipping in fourth
- High pitch "whine"
- '07/'08 FLH IDS pulley
- fgall4355
- Can anyone tell me
