View Full Version : Transmission/Clutch and Primary Related
  1. 08 Touring primary tools needed
  2. Primary Install Advice
  3. Clutch disengagement
  4. chain conversion for 09 Road Glide
  5. Primary Noise
  6. belt drive
  7. chain cutiing into cover
  8. Inner Primary Bearing
  9. Engagement Point? Tried 1/4 Turn
  10. dump and oil drip
  11. Oil in primary case
  12. Tranny Shaft
  13. Link to catastrophic tranny needle bearing failure 02 FLH SE RK!!
  14. primary knocking
  15. trans drive sprocket change
  16. 66 slovel. 4seed to 5speed swap. what trans?
  17. shift arm loose on shaft of bagger
  18. noise in primary
  19. 4 speed kicker cover problem
  20. Shovelhead Clutch Overheated
  21. Remove outer primary on 07 Wide Glide
  22. Excessive chaincase noise 2003 FLSTC
  23. ez clutch
  24. slipping
  25. Help - I messed -up
  26. Leaking main seal on 4 speed trans
  27. clutch removal troubles
  28. putting in gear loud klung
  29. Clutch problem?
  30. ate starter gears again
  31. Squeal from clutch/primary on decel
  32. 4 speed to 5 speed change over
  33. What year is this tranny??
  34. I get nothing
  35. Inner primary seal for starter shaft
  36. 89 ST clutch?
  37. "Buzz" in first gear
  38. Tranny internals case swap
  39. Clutch Removal
  40. Hydraulic clutch problem
  41. Tranny drain plug washer
  42. What Happened To First Gear?
  43. shifter fork? bike stuck in first......need help
  44. Clutch Question
  45. Need Transmission Help
  46. how do you tell year/style of tranny?
  47. main drive gear removal
  48. how to check gearbox oil level
  49. Belt drive to chain drive???
  50. tranny leak
  51. 07 Night Train tranny/primary help needed
  52. '89 FXR clutch
  53. Klank Klank Klank goes the sportster
  54. hayden m6 chain tenisoner
  55. 06 softail - Hard to roll in Gear with clutch pulled in
  56. OIL seal cork washer
  57. inner primary ?S please help
  58. I have a question about shifters???????
  59. Frozen Clutch hub removal
  60. Looking for help installing baker 6 speed in 4 speed shovelhead frame
  61. 4-speed /Evo swap
  62. How many steel / friction plates?
  63. how much oil goes in tranny?
  64. Tranny swap
  65. Clutch Assembly Removal
  66. Shifter prob!
  67. Feels like the clutch hasnt disengaged
  68. suicide shift
  69. Help with EVO set up
  70. kick start install
  71. Filled my Primary from the drain hole
  72. auto primary chain adjustment
  73. raising shift lever; sportster 1200
  74. transmission life
  75. gear ratios on 78 lowrider
  76. I'm lost and tired.. Maybe someone can help!
  77. 1st gear
  78. Shifter Linkage, 88 dresser
  79. '91 FXR shifter question
  80. Bleeding the clutch
  81. Primary Tenisoner Shoe ???
  82. 1988 RK striped shifter shaft
  83. Clutch hub and clutch housing removal
  84. 1st gear problem
  85. Easy Clutch Adjustment
  86. Checking oil?
  87. Clutch cable
  88. 02 FXDL feels like missing gears
  89. Adjusting a 08 clutch with just the cable?
  90. Try to find clutch info need help
  91. Preloading the compensating sprocket
  92. suicide clutch
  93. problems putting bike in neutral!!!
  94. Removing Stripped Bolts From Derby Covers
  95. Belt & Pulley Service/Replacement Time
  96. SYN 3 In The Trans.
  97. Rear Belt Drive Noise
  98. 06 Dyna False Neutral
  99. Making A Custom Shifter Rod
  100. Hydrallic Clutch Installation
  101. EVO Belt Drive Installation
  102. Fixing 4 Speed Tranny Leaks
  103. Transmission Gear Information
  104. Clutch Cable Replacement
  105. Dyna 6 Speed Amendment
  106. Clutch Talk And Tips
  107. Harley Transmission Recall (Dyna)
  108. Clutch Cable Needing Lube Often
  109. Clutch Q & A
  110. Early XL Clutch Problems
  111. Sporty Trans Vent Line
  112. E Z Pull Clutch for Sporties
  113. Clutch Cable/Handle Lubrication
  114. 2006/ 6 Speed Info
  115. New Automatic Primary Adjuster (HD) *
  116. Reduced Effort Clutch (HD)
  117. Jim's 6 Speed Install
  118. Clutch Parts Breakdown
  119. Drive Train/ Clutch FAQ's
  120. Compensating Sprocket Explained
  121. Speed Sensor Pickup Problem (pics)
  122. Bagger Transmission Oil Change
  123. Primary Gasket Replacement Pins
  124. HB 125 Install
  125. Hayden M6 Primary Tensioner
  126. Speed Sensor Pickup Problem Symptoms
  127. Primary Lube
  128. Making A Primary Chain Tool
  129. EZ Boy Lite Clutch Setup
  130. 4 Speed Transmission Repair Tip
  131. Primary Chain Case Servicing Tip
  132. Clutch Adjustment The Easy Way
  133. Adjustment and Troubleshooting of Clutches.
  134. Diagnosing Various Transmission Problems
  135. Clutch Cable Replacement Tip
  136. Clutch Adjustment By The Book
  137. VPC Clutch Install
  138. Primary Chains & Noises
  139. Primary Chains 101
  140. Overdrive Transmission vs. A Pulley Change?
