View Full Version : Engine Diagnostics , Alarm, and Fuel Injection Issues
  1. 2001 night train problem
  2. DTC U1040 ?? What is this ??
  3. Help Bought TTS Master Tune, Have Map
  4. Are EFI maps exact to aftermarket part combinations?
  5. Fuel Pressure Adjustment '08 models?
  6. Stage 1 Air Cleaner Kit
  7. Now Whats Wrong?
  8. Rear-End Variance on Softail Models
  9. Base tune for the SERT
  10. ?? does anyone know how to remove the fuel pressure regulator
  11. 03 Ultra Dies When Hot
  12. Resetting AFV
  13. Lube for throttle grip?
  14. 04 electra glide oil light on
  15. 04 road king help!!!
  16. 09 touring trouble codes..p1511 and p2101?
  17. PC V by fuel moto help
  18. early EFI-1995 ISSUES??
  19. Thank you All
  20. Wandering idle on MM
  21. dyna 03 / blinking lights/ gauges not working
  22. Manual security?
  23. key fob programing help me
  24. Another Security System Issue
  25. another TSM Problem
  26. Diag Code: P0562 Battery Voltage Low EFI
  27. directionals flashing on start up
  28. Repair Manual
  29. Dealer "Fixed" My Intermittent Check Engine Light
  30. help with tssm code(for disarming)
  31. 06 Heritage Softail Security(help!!!)
  32. Alarm question.......
  33. Need help retrieving codes on 03 rk
  34. V&H fuelpak insight
  35. Chirpless alarm
  36. Super Tuner ECM error
  37. Fuel Pump/Electrical issue
  38. 2002 roadking classsic fuel injected ant info
  39. Loud Popping/Backfire when Starting
  40. o4 wideglide just dies
  41. fuel pressure light comes on while engine is running
  42. Can't disarm alarm
  43. Code issue cvo 08 springer
  44. V & H Fuel Pak Fitment
  45. HELP....I'm DEAD
  46. SE Pro Tuner Software
  47. P1351 and 1354 Error Codes
  48. Trouble Code Set 01 RKC
  49. RPM Gauges
  50. Power Commander
  51. Race tuner
  52. How do you turn off the alarm to work on the bike?
  53. TSSM Antenna Routing?
  54. 09 alarm doesn't arm properley with LED's & stablizer
  55. Valve Pocket Question
  56. Disarming Alarm? '06 Street Bob
  57. Radio Shack alarm for 09?
  58. 2003 Fat Boy EFI Running Issues
  59. Method to clear a fault code?
  60. fuel pump
  61. Road King EFI Help
  62. scorpio alarm?
  63. Factory Alarm PIN
  64. power comannder on a rocker
  65. Installing smart security on 007 ultra?
  66. Alarm Issue??
  67. 99 Road King with Code 35????
  68. 07 Heritage Srecurity System Indicator Lamp Stays Lit
  69. Diagnostic Error Codes 03 Road King???
  70. sweeping guages 09FLHX
  71. Which EFI Kit?
  72. Engine Code Help Needed
  73. need sert map for 08 ultra... help
  74. 07 Dyna EFI troubles
  75. Harley-Davidson Security System Smart Siren II
  76. need '99 bank angle sensor signal spec
  77. 07 FXDB H-D Security Sytem Install Question
  78. Negative acceleration
  79. Daytona Sensors
  80. 2006 Dyna 02 Sensor Info
  81. Tuning Fuel Injected Bikes
  82. 2006 Dyna DTC Codes (Diagnostic Trouble Codes)
  83. Checking TSM/TSSM Trouble Codes
  84. Alarm Auto Enabling/Disabling
  85. Setting Idle On MM Systems
  86. TFI/DFO Setup & Installation (video)
  87. Understanding EFI Better
  88. SERT Users Manuals
  89. TFI Installation On 05 Bike (Video)
  90. New TFI For 06 Dynas -w- Installation Instructions
  91. PC III Setup Help
  92. Installing A PCIII
  93. 06 Bikes Running Lean
  94. HD Factory Security System
  95. Terry Components FI Management
  96. HD Race FUELER installation Instructions
  97. Harley Fuel Injection System Explained
  98. PCIII, SERT, TFI or DFO ?
  99. 06 Dyna Download (with 02 sensors)
  100. SERT, What is it?
  101. TCFI Twin Cam Fuel Injection
  102. Hot Idle speed On FI Bikes
  103. Daytona Twin Scan Tuning
  104. FI Baggers Running Poorly
  105. Alarm Transport Mode Setting
  106. Alarm Storage Mode Config
  107. Battery Disconnects and Re-Configuring Alarm
  108. Alarm Sensitivity Adjustment
  109. TSM/TSSM Rapid flashing Signals
  110. H-D Factory Security System Install
  111. Ignition Advance Explained
  112. LM 1 Engine Tuning Tool
  113. Installing The SERT
  114. Twin Tech FI Controller
  115. Good Price For TFI/DFO Fuel Management System & More (new source)
  116. 06 TSSM Update Info
  117. Fuel Injection Answers
  118. TFI/DFO Updated Info
  119. Power Commander Explained (PC III)
  120. Exhaust Temp Sensor Values *
  121. Speedometer Values
  122. Engine Sensor Values Chart
  123. Marrying NEW TSSM To Bike
  124. Testing TPS Values on Fuel Injection
  125. DFO/TFI -PC III Comparisons
  126. Daytona Twin Tec Harley Scan Tool
  127. Cruise Control Diagnostics and Codes
  128. Cruise Control Initialization
  129. Electronic Fuel Injection and The Power Commander
  130. Alarm Key Fob Assignment
  131. Engine Compression..How To Check It
  132. Know Your Security System
  133. TSM/TSSM Password Relearn Proceedure
  134. TFI / DFO Pot Settings **
  135. Fuel Injection controllers another view...*
  136. EFI Performance calibrations
  137. SERT, PCIII and TFI COMPARISONS
  138. Fuel Injection Terms Explained
  139. How to test Delphi systems ECM codes (00-03)
  140. Testing ECM codes (04 - 06 Serial Data bikes only)
