Hacked, Conversions and Trailering"Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts"
A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Cozy or Inder make sidecars that fit pretty well on most Harley Davidsons with the Universal Mounting Kit. I would recommend using the universal upper mounts, however, I found it best to fabricate your lower mounts. They will fit better. I put this hack on my wife's sportster and it rides like a dream with both of us playing around town.
Best of luck!!
My 05 FLHTCI had to be prepped first so the 1999 TLE would fit. I had to remove the entire exhaust just to mount the passenger rear floor board bracket and also replace the stock short clutch cable with a longer cable because the longer one is routed different. Change the oil sending unit into a 90 degree position, remove the brake reservoir and relocate it between the tubes, replace tall foot brake pedal with a short pedal and hook up a "T" fitting for the brake line at the brake switch underneath behind right passenger floor board. IF I ever wanted to remove the Car it could be done and all I would have to do is cap off the brake line at the "T". All this cost me less than $350. The Car I paid less than $4200.
Having this one mounted on my 1996 FB right now. To busy right now to do it and I need it done so the Dealer is doing the work. They have done a lot of sidecars.
