Stator Replacement
The "proper" way is to remove the inner primary cover - on some models there's not enough clearance to get the rotor out - the rotor gets hung up on the opening of the inner cover. The reason for the grinding is to gain clearance so you DON'T have to remove the inner primary cover to remove the rotor. Most people feel the amount of material that needs to be removed is not enough to weaken the casting, and it saves an hour of labor time.
For Christ's sake..............the 2007 Softail manual specifically states on 8-17 under Alternator of section 8 (electrical) under "Note" "It is not necessary to remove the inner primary chaincase to remove the alternator"
There was another thread that makes it look easy. The thread is about replacing compensator but you will get down to the point where you can drop a new stator in. The grinding is so you can slide the rotor off the shaft to get to the stator without having to pull the inside primary cover off the shafts.
https://www.hdforums.com/forum/touri...it-w-pics.html
Guess I messed up when I changed my stator. Left the inner primary on...
Gotta love it when folks give advice on stuff they haven't done themselves.
"Oh yea, my ex brother-in-laws, second cousins, parole officer said it was so!!!"
Beav
Beav
Hey, Beav, you got a 99 I think. Plenty of room on that primary setup. My 05 is good too. I think it was 06 or 07 when the clearance issues started?
Yea but, you took your jugs off....I don't think he'll have to do that. LOL
Inner Primary case needs to be ground when installing the SE COMPENSATOR and not when replacing the stock rotor stator. Mine slipped right in and out no issue. 06 dyna
