Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Forums > General Harley Davidson Chat
Sponsored by: WheelDock
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 11-03-2009, 02:01 PM
Badlarry Badlarry is offline
Hang Around
2001 Harley Davidson Road king
Default Twin Cam 88 chain tensioner
I was at the local Harley Dealer the other day when a friend of mine told me that if your twin cam has around 40,000 miles on it, you should have the cam chain tensioners replaced and possibly the cams. This is the first I have heard of this. Whatever happened to the stories you hear of people putting over 100,000 miles on and have done nothing to the motor? He also told me that pieces of the tensioners will break and go into the oil pump and loose oil pump pressure. Tell me what you have heard or experienced.
Badlarry
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
Badlarry [Never judge a man until you walk a mile in his moccasins]
Old 11-03-2009, 02:03 PM
HarleyGoodies's Avatar
HarleyGoodies HarleyGoodies is offline
Premium Sponsor
This is true. The cam chain tensioner shoes are the weak point of the twin cam 88's. Pull the cam cover off and have a look at the shoes. They are the orange things. Do a forum search, there are a ton of threads about this subject.
__________________
60 DAY MONEY-BACK GUARANTEE - FREE PRIORITY SAME DAY SHIPPING
EXTENDED PROMOTION - GET A FREE SKULL BANDANNA WITH EVERY ITEM ORDERED
Old 11-03-2009, 02:04 PM
Geoff's Avatar
Geoff Geoff is offline
The tensioner won't necessarily break, but the shoes will be worn by 40k miles. Harley offers an automatic tensioner for the TC88.
__________________
2007 Softail Custom
1994 BMW K1100RS
Old 11-03-2009, 02:06 PM
petemac's Avatar
petemac petemac is offline
Yep, it's a wear item, inspect and replace as needed. The cams are unrelated but a lot of people swap them if they're going to replace the existing tensioner setup. I did.
__________________
2006 Road King Classic
Vivid Black
95" with heads ported by Big Boyz
V&H True Duals and Ovals
SE hydraulic tensioner upgrade
Andrews 26 cams
SERT
Old 11-03-2009, 02:11 PM
TazInCT's Avatar
TazInCT TazInCT is offline
Senior Rider
2000 Harley Davidson Deuce
My Garage
You should definitely have a look at them to see where you stand. There has been a problem with the tensioners as your friend explained. I changed mine at 25K and they were not shot and I would have been comfortable going another 10K before having another look, but I changed them while I was in there. Your cams are fine, but lots of people also decide to change out the cam while they are in there for performance reasons. Also, if you change to gear drive cams, you will never have to worry about the tensioners again. Me, I changed the tensioners and through in some Andrews tw26 cams for some low end torque but neither were necessary.... yet.
__________________
http://www.hdforums.com/forum/picture.php?albumid=589&pictureid=2764
I gave up exercising for health reasons...
The friction between my legs almost set my underwear on fire!
Old 11-03-2009, 02:19 PM
Scout's Avatar
Scout Scout is offline
A real easy check without pulling the side off is next time you do an oild change is to cut the oil filter in half and look if the is any small orange plastic in the filter/oil. If so, the tensioners are bad and need to be replaced.
BTW, just pulling the cover off only shows one tensioner, the back one is hard to check, so if the front loks O.K. that really doesn't tell the whole story.
__________________
Old 11-03-2009, 02:20 PM
FastHoss's Avatar
FastHoss FastHoss is offline
Changed the tensioners at 30,000 on mine,not even half wear,lifters,cam bearings,adj.pushrods.Was in it already so went ahead and changed them out.Unless I hear something or see something out of the norm,I will not open her up again.I let the internet hocus pocus get to me.
__________________
2005 Electra Glide Standard
2005 Springer Classic
Old 11-03-2009, 02:28 PM
hpfatboy's Avatar
hpfatboy hpfatboy is offline
Thumbs up
Just REPLACE everything with GEAR DRIVE and you"ll never have to to WORRY AGAIN!!! Providing your CRANK RUN-OUT IS WITHIN SPECS!!!
__________________
  • 04 FATBOY 95" MOTOR BUILT BY JARZ PERFORMANCE, HOT-ROD HARLEYS. 97 HP + 110 TQ
Old 11-03-2009, 03:27 PM
morepowr's Avatar
morepowr morepowr is offline
Prospect
I replaced mine with gear drive at about 35K. They were worn and had a small chunk out of one. I went with S&S 510 and couldn't be happier with them.
__________________
'06 Wide Glide
"Accomplishing Nothing!"
Old 11-03-2009, 03:33 PM
schumacher's Avatar
schumacher schumacher is online now
Hellboy
2003 Harley Davidson Softail Standard
It's a lie.............Harley would never build a motor with inferior internal parts.
__________________
2003 FXST
Patriot Guard Rider 163818
V-Twin Cruisers MC Springfield Ohio Chapter President
Tags
2004, 2005, 88, cam, camshaft, chain, check, electra, glide, harley, king, replace, replacement, road, shoes, tension, tensioner, tensioners, twin, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
