Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Forums > General Harley Davidson Chat
Sponsored by: WheelDock
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 11-03-2009, 08:06 PM
2kids3pets's Avatar
2kids3pets 2kids3pets is offline
Senior Rider
Quote:
Originally Posted by Badlarry View Post
I was at the local Harley Dealer the other day when a friend of mine told me that if your twin cam has around 40,000 miles on it, you should have the cam chain tensioners replaced and possibly the cams. This is the first I have heard of this. Whatever happened to the stories you hear of people putting over 100,000 miles on and have done nothing to the motor? He also told me that pieces of the tensioners will break and go into the oil pump and loose oil pump pressure. Tell me what you have heard or experienced.
Badlarry
No one ever said they were maintenance free
Quote:
Originally Posted by jbnl163 View Post
What does the stealer charge on average to replace the tensioners?
Got a quote from a local shop here in Central Canada $500.00 for the hydraulic tensinors and oil pump upgrade parts only and another 4 to 6 hrs labor. Im guessing by the time its all said and done you be look at a grand
Quote:
Originally Posted by oldairboater View Post
All these people give you the advice to check the oil filter, and tensioner shoes but I don't hear too many of them telling you how to check the inside shoe. Shoes are for feet.
Ask and you will be rewarded
How to check them:
http://www.harley-davidson-hangout.c...ner-check.html
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
Old 11-03-2009, 08:08 PM
justanotherjim justanotherjim is offline
Hang Around
Location: Mohave valley AZ. We aren't in hell, but you can see it from here!!!
I have a '00 EGC that's in the shop right now because of the tensioner going bad. I bought the bike used from the "stealer" BUT! I also bought an extended warrenty!!! My cams are toast,one tensioner was in pieces, and the shop guys say that my oil pump is probably gone, too!
So I said COOL! Gonna get me a gear drive and some cams with a little bit o' grunt and it'll only cost me fiddy dollars and what ever the differance is between stock and the new cams !!!! Thank you HD ESPs!!!
__________________
where's the remote!!!
2000 flhtc bone stock!
hawgwired radio adapterW/ sony marine stereo hog tunes front speakers.
Old 11-03-2009, 08:14 PM
Wallaby's Avatar
Wallaby Wallaby is offline
I would look at Gear Drive cams if I was near the end of the TC chain drive lifespan, gear drives are a better system IMO, but do add some noise, not discernible over the correct non-EPA compliant exhaust though.
__________________
Flat out like a Lizard drinkin'......
Old 11-03-2009, 08:29 PM
WWECOUGAR's Avatar
WWECOUGAR WWECOUGAR is online now
Prospect
Take heart : Honda CBR's loose cam chain tensioners too! Of course, the aftermarket replacement is better and relatively inexpensive, and can be easily replaced while doing a valve adjustment. A grand to replace these things? Woah! hope mine don't go!
Old 11-03-2009, 08:32 PM
dennyo's Avatar
dennyo dennyo is offline
1999 Pontiac Firebird
AND Then if you decide to do dat ,
You Gotta Figure Out What CAM you want...
__________________
Old 11-06-2009, 09:55 PM
Hang Around
Dennyo, you hit that right on the button! I knew there were a lot of different companies out there, but MAN!!!
My shop guy is really pointing me towards the 95" and S&S cams upgrade, but i gotta be carefull with my ESP being voided, so I'll probably do the SE 255s. They seem to be the best bang for the buck for what I do. Daily driver and some 2-up with momma.
__________________
Old 11-06-2009, 10:30 PM
xxxflhrci xxxflhrci is offline
These had 20k miles on them.
__________________
2000 Road King Classic. Andrews 26G cams, SE Stage I, DFO, V&H True Duals with Samson Fishtail Mufflers.
1977 XLH, Nearly bone stock.
Old 11-06-2009, 10:32 PM
These had 52k miles on them:
__________________
Old 11-06-2009, 10:34 PM
It's a crapshoot whether they wear or not. There is no rhyme or reason why some wear quicker than others. The only way to check them is to look at them, IMO. Cutting an oil filter open tells you not much, IMO. So you have some orange in the filter. That doesn't mean you filters are toast. It just means that a wear item is wearing. I'd guess that the tensioners that wear slowly won't shed enough orange crap between changes that you will even be able to find it in the filter.
__________________
Old 11-08-2009, 10:31 PM
harleydavis harleydavis is offline
Quote:
Originally Posted by morepowr View Post
I replaced mine with gear drive at about 35K. They were worn and had a small chunk out of one. I went with S&S 510 and couldn't be happier with them.
+1.......I replaced mine at 35k and put in the S&S 510 gear drive cams and really noticed the difference in torque and HP.
__________________
2000 Fatboy
95" Big Bore
Head work by Short Block Charlie's
S&S 510G cams
V&H ProPipe HS
Tags
2004, 2005, 88, cam, camshaft, chain, check, electra, glide, harley, king, replace, replacement, road, shoes, tension, tensioner, tensioners, twin, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
