I have an 09 Electra Gide Standard with about 9800 miles on it. Today I came to a stop light and when I went to take off I had no throttle response. The bike just idled. I shut it down, turned it back on and had throttle agian. Now, The check engine light comes on while the engine is idling for the first 10 seconds and goes off but the bike seems to run fine. Has anyone had this same problem?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
08 Roadglide had the same issue Dealer could not find any issue Suprise!, I fount the switch housing to tight causing the wires to ground and fail. Opened up switch housing to make sure wires were in the cutout were they should be. Properly tighten clamp. Good to go 900 miles no issue
Not heard of that one.. have heard of several that has a lag in response time....
If u do find an solution be sure to post it for later for reference for others.
the check engine light stays on and goes off because it has a code stored in it. you can do a quick search on here for steps on reading the code. I know fuelmoto had it posted on there website at one time and harleygoodies just posted it earlier today in one of his posts (I just don't remember which one).
