Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Forums > General Harley Davidson Chat
Sponsored by: WheelDock
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-19-2009, 11:47 AM
Lardog666's Avatar
Lardog666 Lardog666 is offline
Prospect
Default Winter Storage: To Drain or Not to Drain, that is the question
Having read that awesome post about winter storage that Da Gumpmeister put out there, I have a question for all you experienced HD owners.
I've got friends that say you should store your bike with a full gas tank (with the stabilizer additive) as Da Gumpmeister mentioned.
yet others say drain your tank, it stores easier.
Does it depend on the age of the engine?
What are the pros/cons?
How do you store yours?
& to those fortunate enough to not know what winter is, It's when dry water magically falls from the sky....
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-19-2009, 11:55 AM
Wallaby's Avatar
Wallaby Wallaby is offline
Full tank (with stabilizer) to eliminate condensation that leads to rust
__________________
Flat out like a Lizard drinkin'......
Old 10-19-2009, 12:02 PM
Maimas's Avatar
Maimas Maimas is offline
Senior Rider
2008 Harley Davidson Fatboy
Fill it... All fluids should be topped off and if possible, freshly changed before storage.
__________________
Sh!t Happens...
I do whAt ever my Rice Krispies tell mE...
Old 10-19-2009, 12:13 PM
Da Gumpmeister's Avatar
Da Gumpmeister Da Gumpmeister is offline
GOOD ? ....
Here's the diff...............TEMPERATURE !!!
IF "cold", fill it, no air space for condensation. If you have a heated shop, grudge, or keep it in da house, like J Dub, then drain it, if you like. But IMFUO, run it 'til ALL is gone, from carb/efi and lines. No chance of 'gunk/varnish' happening, then.
Mine, 'normally', are kept in a heated shop. I actually drain 'em, cause I end up pulling everything off, to detail the scoots over winter. This year, may be different, not much work, no xtra $$ to keep a shop heated, 24/7.
BUT the post is 'basically' designed, for "COLD" storage.
Hope that 'helps'.
__________________
U don't quit ridin' cuz U git Ol', U git Ol'cuz U quit ridin'
American by Birth - Biker by Choice - Saved by GOD's Grace
So Many Bikes, So Few Bikers.
Old 10-19-2009, 12:23 PM
coupe55's Avatar
coupe55 coupe55 is offline
Hang Around
Default stabilizer
I put the stabilizer in every gas engine machine I store, I also run the engine with it in it to get it up in the carbs/fuel injection system. Float charger on equipment with battery's or take them out and store them somewhere warm.
On the motorcycle/Trike I use an outdoor fitted cover in the garage. Since mine is not heated I put a trouble light under the tarp on the floor with a 100 watt bulb. They have so much electronics, ECM, fly by wire throttle and such, I do not like the moisture environment of an unheated garage.
We have a good day or two even in the winter most months so I try to take the cover off and ride the bike/trike at least once a month. I don't take the battery out of the bike/trike, just a low amp float charger.
If you don't have a controlled temperature garage the tarp/cover with a troublelight will keep them warm and dry. Just be carefull and place the troublelight under the bike in a clear area with plenty of room around it. The cover will hold enough heat in with just a light bulb to help with some of the corrosion and keep the battery from freezng.
__________________
Life is a great teacher, unfortunately it kills all its pupils!
If all that exist is just an illusion, then I definately paid to much for my Harley!
Old 10-19-2009, 12:59 PM
Lardog666's Avatar
Prospect
Quote:
Originally Posted by Da Gumpmeister View Post
Hope that 'helps'.
Immensely!!! I can't tell you guys how much $$$ I've saved just by joining this Forum...
I had a feeling that there was a definite reason to store her filled... now I can counter all the friendly drunken arguments my buddies & I have with the condensation/rust in the fuel lines angle... all y'all defintely rock!
Old 10-19-2009, 01:05 PM
46knuck's Avatar
46knuck 46knuck is offline
Prospect
I bought an old shovelhead from a friend that had been sitting for 6-7 years. The gas tank was about 80% full. I drained out this old gas as it was bad. The area above the gas line on the tank wall had some rust. The area below that looked almost like new.
Keep it full as possible!
__________________
2003 Heritage softail
2003 Deuce CVO
2000 Dyna low rider
1946 Indian Chief
LIVE TO RIDE, RIDE TO LIVE
Old 10-19-2009, 02:21 PM
oldairboater's Avatar
oldairboater oldairboater is offline
I don't do long time storage on my motorcycles but I do on my generators. I always drain all of the gas out of them---I mean all. Spray the inside of the tank with a light coat of oil---not wd40---real genuine oil. Some of them sit for over a year without fuel in anything. We get cold and warm all winter with the concrete even sweating. If I need them I add fresh gas and run them till I don't need them anymore. After use I change the oil, drain the tank--fuel lines--carb, spray oil in tank and let sit. Never had a problem over them sitting but someone I know that has a repair shop makes easy money over improper stored small motors. Storing gas down here in anything is asking for problems after three or more weeks. If I was storing a bike I would do the same thing. JMO
__________________
JB
Old 10-19-2009, 04:52 PM
cdestuck cdestuck is online now
Agree with the full tank deal. Mess around with tractors a bit and talk with others in a forum and seems like the tractors with rust problems in the tanks are the ones left sitting without full tanks. Stabil or Seafoam a must!
__________________
Dan Stuckey
Altoona, Pa
Old 10-19-2009, 07:57 PM
TheJimer's Avatar
TheJimer TheJimer is offline
Full tank with stabilizer and a trickle charge on the battery and you will be good to go in the spring; that’s what I used to do before I got smart and traded winter for 12 months of riding season!
__________________
Stay Safe Out There!!!!
JIM
Great American Classics...
CORVETTE & HARLEY-DAVIDSON !
Tags
carb, cons, davidson, drain, fogging, fuel, harley, heating, home, injected, oil, pros, storage, storing, tanks, topping, winter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
