Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Forums > General Harley Davidson Chat
Sponsored by: WheelDock
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
  #111
Old 10-04-2009, 08:54 AM
Kabear's Avatar
Kabear Kabear is online now
They won't be able to fix it. Just spent $400 on my bike to have the oil leaks fixed. I think it is their seals, they don't. I'm now looking for a better source of oil seals for my bikes.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
The only difference between Ignorance and Intelligence is there is a limit to Intelligence
"Oppressors can tyrannize only when they achieve a standing army, an enslaved press, and a disarmed populace." James Madison. Well two down, one to go!
  #112
Old 10-04-2009, 09:51 AM
John TN's Avatar
John TN John TN is offline
"Moderator & Resident Troll Tracker-IWFY"
I'm in the process of reinstalling my tranny,,, the only seal that was leaking was the shifter pawl shaft seal,,, one thing I noticed of all the seals this one is the only single lip seal,,,, all the others were/are double lipped,,,, I'm going to add an o-ring in between the flat washer and the shifter pawl shaft seal, thickness just enough to put a little tension against the seal and help keep out dirt. You cannot protect the seal from the splines going through it because of the shifter pawl guide tube so it's possible to damage this seal on installation even with grease,,, one rule of thumb never slide a shaft through a seal without lubrication and check for sharp edges, burrs etc. on anything that goes through the seal.
Quote:
Did this same dealer do the prior work to this bike prior to you buying the bike? Loose bolts/screws etc, stator about to fall out?,, (never heard of that before) is very, very poor workmanship turned out by a certified HD mechanic or any mechanic as far as that goes,,, the inner primary requires the use of a silicone sealant on the fasteners plus the o-ring seal, if these were loose it would have to be completely redone, there is locking tabs for these bolts as well.
Are you able to actually see the leak you're having now since everything was tightened up? Really It sounds to me like this is going to have to be taken back apart inner primary and all and then redone with new seals, gaskets and a competent mechanic.
Quote:
Originally Posted by tully_mars View Post
Update:
Took the bike out for a ride, noticed after a stop oil leaking from the rear of the primary seal. Had some more in the garage so back in HD's garage for another try.
__________________
  #113
Old 10-04-2009, 10:41 AM
jamesw's Avatar
jamesw jamesw is offline
Prospect
Don't know about that. Mine is done, and leak free. I did notice some differences in the new seals versus the old; maybe better designed?
My bud was laughing his azz off because when I stopped at the oil change place to get rid of the old fluids and asked them for 4 of the paper floor mats they put in your car to spread out under the bike....
__________________
At The Harley Museum
1999 FLHTCI
95CI with 10.25:1 Cast pistons
Heads ported and polished with Valves recut
Andrews Gear Cam Drive with Andrews 54 Cams
Jim's Hydrosolid II Lifters & Power Commander III
  #114
Old 10-04-2009, 11:58 AM
tully_mars tully_mars is offline
Hang Around
Not sure what dealer worked on this bike prior to me owning it. If it leaks again on the primary after I pick it up this time not sure what I am going to do. If I start switching dealers to try and get it fixed then they all can blame each other for problems.
The leak is coming from Primay Seal on the rear part of the motor around the 2nd or 3rd bolt from the back. Glad I bought the 1 year HD warranty with the bike. Never going to pass that up on a used HD.
__________________
TM
You cannot multiply wealth by dividing it."
Dr. Adrian Rogers,1931 - 2005
  #115
Old 10-04-2009, 12:45 PM
maddoggie's Avatar
maddoggie maddoggie is offline
I also have an 07' Ultra it leaked also , turned out to be the inner primary seal, My Dealer fixed it and it leaks no more
__________________
"Where ever you GO!....there you ARE!"
Tags
2008, 2009, davidson, flstc, frame, harley, harleys, heritage, honda, leak, leaks, motorcycle, oil, softail, ss, vtx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
