I only weigh around 220 and I've done it a couple of times myself. Its the delay in the throttle by wire. I never did it on any of my other bikes with cable throttle.
Gary D.
That is what the cops around here have said. when doing slow riding they have to compensate for the delay in the resonse
__________________
1999 XLH 883 Cobalt Blue, S/E cams, S/E AC,
Santee .45 Cal Duals
2003 Anniversary FXDL Vivid Black & Silver S/E AC Bassani Pro Sreets
Try getting the RPM's up to about 3500-4000 and dumping the clutch, it will not lug then J/K, I usually take off from about 1200-1500 RPM and still feather the clutch while applying more throttle.
__________________
Take off parts for sale in the Dyna parts for sale section
Don't lug a Harley V twin, first thing I learned many years ago. If you are starting in first gear ,you can feather clutch to start slow ,but give it more throttle.
My other bikes could pull the front tire and carry it with just a flick of the throttle, so why won't my Harley? It's flawed logic.
You need to roll the throttle as your releasing the clutch. It's normal.
__________________
2009 Street Glide - Ness Big Sucker, Jackpot Dyno Tuned mufflers, PCV, Slam Kit, Mustang Tripper Solo
2007 Nightrain - 107ci - lots of money.
2005 Deluxe - Stg1, Lowered, Under Construction
I have had the same problem with our 09 ridding two up. It almost sounds like the primary chattering. I never once had that problem with older Harleys.
I've noticed the same thing on my Cross Bones but not on my Triumph Rocket 111.
But then then there is a slight difference in the torque available
More revs and more clutch solve the problem but can't do much for the clutch
__________________
You don't have to be a weatherman to know which way the wind blows
