Fuel/Carb RelatedFind tips on fuel and carb related issues here.
Welcome to HDForums.com!
Welcome to HDForums.com.
Being an ASE Certified Master Auto Technician for 20 years, I know on every fuel injected car/truck i've ever owned I never had to do anything to the ecm when i did a K&N a/f and a Flowmaster on any closed loop system.
I was wondering the same question on my 09 since it has the same closed loop system as my 04 Silverado. Some say the download alone, some say race tuner some say it will compensate as it has wide band 02's.
I don't know who to believe. I put slipons on my bike a few days ago now I want to do the a/c but want facts, not money sucking BS!
Delphi ecm... check
delphi fuel injectors... check
delphi wide band 02 sensors.. check
delphi map and crank sensors... check
you would think with today's technology that the ecm would pickup on the increased air flow and richen the system up.
It's the same fuel managment system that's in my 04 silverado for christs sake!!
Your trying to compare apples and oranges. This ain't your 04 silverado
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________ 1964 FLH Duo-glide/
2006 VRSCA, Powerline Style exhaust, Midwest Floor Boards, Ricks 5 gallon fuel tank, PC III, PC III LCD, Semi Topless, Slipper Clutch, 30 tooth HDI sprocket, CVO cams, RICOR INTIMINATORS
I refuse to have a battle of intelligence with a unarmed person
Well i just installed a pair of Vance and Hines oval slip ons on my 07 Roadglide and yes V&H on their website says that the 07's do not need the remap download because of the 02.
The Bike rides and sounds gread and i was thinking of getting the Wide Band 02, I did intall the Stage 1 heavy breather .
Just don't want to waste any more money , everyone says something diffrent
Confused ?
Well, I posed the same questions, and did a lil reading.I have an 09 Fatbob, I installed a set of slipons by Khrome Werks, and a stage 1 AC. As it stands, I noticed an immediate power, throttle response change on my scoot.
The change was both in MPG, throttle response, as well stand still idle.
All 3 changes wrre for the better.
Now granted, those aren't indictions of proper. Engine function. Nbut I'm old school, and an idle good or bad will tell you how well the engine is performing.
On that note. My research has also pointed to the load capacity of the ecm and its limited ability to compensate for the engines high end throttle.
So, if you are looking for an overall fix to the AFR issue, and better manage the performance and stamina of your ride,
XIEDS, or systems like the Power commander will go a long way to "Enhancing" an already well oil machine.
TRUST ME! you will know if you need the download... as i need it severly bad. it feels like it occasionally just doesn't feel like firing on a cylinder out of the blue. it's really cool especially when your in the middle of a slow speed turn with your wife on the back.... yeeeeehawwww.. mine goes in next week for the hd download aka bandaid patch.. the so called junk patch worked great on my cousins 07 rk true dual, thunder header, hiflo a/c
__________________
2006 FLHX BLACK CHERRY
STAGE 1 AIR INTAKE
TRUE DUAL W/ THUNDERHEADER SLIP ONS
CEEBAILEYS WINDSHIELD +3 OTHERS
LOTS OF FUN STUFF, S/E WIRES,WILLIE G GOODIES, ENGINE LIGHTS, FRENCH HEADLIGHT, DELETED DUAL SHIFTER, RIDER BACKREST, QUICK RELEASE BACKREST,ETC. ETC.
