Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Frame/Suspension/Front End/Wheels/Tires/Brakes
Frame/Suspension/Front End/Wheels/Tires/Brakes Frame, Suspension, Brake, and Front End Quesitons should be posted here.
Sponsored by: Progressive Suspension
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-23-2009, 11:33 AM
drstephennix's Avatar
drstephennix drstephennix is offline
Hang Around
Thumbs up
Quote:
Originally Posted by Tech23 View Post
Lotsa useful information....LOL. I did read you do NOT want to go to a wide tire kit, or convert your bike to a softail, or change to a 17" rim. A rule of thumb is one tire size wider in most cases, without needing a wider rim to correctly fit the tire. Of course there are other clearances that will need to be checked as well. I think I would contact Dunlop on the issue to see what they recommend....If they have an E3 in what you are looking for I would recommend that tire (from experience).
Here is a topic I started on another site....you may want to take what you read here and put it to Dunlop to see how they feel about this too.
http://www.v-twinforum.com/forums/wh...mix-match.html
Hope this somehow helps...I know how little choice you have when wanting to go (safely) to a tire that is just a little bit noticeably wider, without running into clearance or fittment issues.
Tech23
Thank you. good info to look into
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
2003 HD Dyna Wide Glide
Anniversary Edition
11kmiles and counting
Screamin Eagle II pipes
Stage 1 build-up
Old 10-29-2009, 01:58 PM
FASTFXD FASTFXD is offline
Hang Around
I have an 03 FXD and I'm pretty sure wheels, etc. are the same as the WG. The only frame difference I'm aware of is that the FXD has less rake.
OEM on my bike is the 150X16. I bought a take-off 160 X 17 with the tire to switch. I've not done it yet, but height and width measure up and it appears the larger tire will fit. It's tight by the belt guard - but measures up okay.
Old 10-30-2009, 02:26 PM
Hang Around
When you get it on, can you post up with the actual results?
__________________
Anniversary Edition
Stage 1 build-up
Old 10-30-2009, 06:17 PM
Hang Around
Yeah, but it'll be a while before I get to it. Ya got me wondering and so I researched a little.
HD switched to the 17 X 4.5 rim size on the 2006 FXD and I'm getting conflicting input re whether or not they made any other changes that would stop me from painlessly switching out wheels. Like I said - it measures up, but is tight.
However, nothing's for sure until you try it...
Old 10-31-2009, 01:44 PM
grbrown's Avatar
grbrown grbrown is offline
To check what size tyre might fit you can check a few things on your bike. To get a 160 in you need at least 3/16 inch clearance between your current tyre and the belt guard. You could also take the guard off, to see what clearance you have between the tyre and belt. On my older bike I replaced the original 130/MT with a 140/MU, but had to modify the guard to get it in, with just 3/16 inch clearance, so you could consider modifying yours.
__________________
Graham
Harley owner since 1974, Founder & Life HOG Member.
1990 Bright Candy HiFi Blue FLHS/2008 S&S V107T, 2007 XB12R, 2003 FXDXT, MG ZT V8.
1990 FLHS/2008 S&S V107T
Tags
03, 2003, bigger, davidson, dyna, fit, frames, fxdwg, glide, harley, rear, size, tire, tires, wide, widest
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
