Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Evo Classic Models
Evo Classic Models All Evo Models
Sponsored by: J&M Motorcycle Audio
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-26-2009, 07:09 PM
Blown 331 Blown 331 is offline
Hang Around
Default Odd whining sound on decel with passenger
For a little back ground I've got a 1993 Softail Custom. I bought it in April of 06 with 13,500 miles on it. I had a base gasket go so while it was apart I added 10 to 1 pistons, air filter, EV46 cam, ported heads, springs, ignition etc. Runs good now. Other than that it just been oil changes and tires. It has been lowered by the previous owner.
Around June of 08 and around 27,000 miles I noticed a whining sound on decel but only with a passenger. The best comparison I can give is an old style police siren. The mechanical type you'd see in a movie that was supposed to take place in the 30s or 40s. If I pull the clutch it quiets down slightly but it is still noticable. Then if I let the clutch back out it gets louder. As I'm slowing down I can tell what ever is making the noise is still spinning quite a bit faster than the wheels. I just rode from Southern IL to Fort Worth TX this weekend and currently have about 42,500 miles on it, the trip was 1600 miles total. I was riding solo for a bit and could hear the noise when hitting large bumps. So that along with only making the noise with a passenger makes me think it might be related to the lowering but it never made that sound for the first 13,000 miles I put on it. It appears to be getting slightly worse. Could it be the belt? Or I assume the front pulley has a bearing, what about that? I was thinking maybe the belt was too tight and got even tighter with a passenger but I have actually never adjusted it, while I'm sure that's probably a bad thing I think that elimintes the possibility of over tightening. Anyone?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
BFMC
1993 Harley Davidson FXSTC
1992 Mustang GT 331 Supercharged 6-speed
1985 Mustang GT
2003 TRX400EX
1985 ATC350X
1985 ATC250R
1984 XR500R
1982 XL500R
1977 F-150 4X4 4-speed 460
1976 TT500
1966 Fairlane
Old 10-26-2009, 08:57 PM
miacycles's Avatar
miacycles miacycles is offline
Sounds lik ethe belt is either hitting something or is too tight. Remember when you are accelerating the belt is thght on top and has slack on the bottom. When you decelerate the opposite is true. It could also be a worn belt/pulley too. Hope this helps.
__________________
John Therrien
SPEED COSTS, HOW FAST DO YOU WANT TO GO ????
Marines may guard the gates of heaven
A job they may do well !!
But it takes the 82nd Airborne
To guard the gates of hell !!
Old 10-26-2009, 09:58 PM
Jim Kraft Jim Kraft is offline
Prospect
Make sure your license plate bracket is not rubbing on the tire. I had an issue on my 99 Softail Custom, after installing a new tire. Mine is lowered some, and it did sound like a siren, and also started wearing a groove in the middle of the tire before I figured out what it was. Took vice grips to the bracket, and it does not do that anymore. Could be something in your fender also. Just something to check, especially if you just changed tires.
Old 10-26-2009, 10:44 PM
rlyons's Avatar
rlyons rlyons is offline
Prospect
Mine was doing the same thing but with the bags full and luggage on the rear. It was the drive belt too tight. I bought the gauge and adjusted the belt and it has been quiet ever since.
__________________
RIDE IT LIKE YOU STOLE IT.
RETIRED USAF
Old 10-26-2009, 11:15 PM
BB4xl BB4xl is offline
Hang Around
Check out your throw out bearing under the tranny cover. My 87 started making that kind of noise. The throw out bearing went. It was kinda of torn up when I took it apart.
Old 10-26-2009, 11:31 PM
daven9113 daven9113 is offline
Prospect
You have described it fairly well. If the bike is not making this sound at idle, then I suspect your belt is loose and hitting either it's guard or rubbing against something else. You should also adjust your primary chain too, but do the rear belt first so you can start eliminating stuff.
dave
__________________
1989 FLHTC- "old blue"
1967 FLH, now chopper kick only
Old 10-27-2009, 12:03 AM
scorchedearthpolicy's Avatar
scorchedearthpolicy scorchedearthpolicy is online now
Senior Rider
Is your bike lowered? I had the same problem with mine because the previous owner weighed 140 lb max and I weight 230 lb so the back of my belt was rubbing so I stiffened up the shocks and its all better now.
__________________
97 FXSTS
U.S. ARMY GULF WAR VET
Old 11-03-2009, 06:43 AM
Senior Rider
Quote:
Originally Posted by wowks View Post
Online betting has now become the fad in football and it has sprung more competition and chances for people to choose wow power leveling what they prefer. A good football tutorial will help a beginner sign up for online website, show and explain the betting choices that are world of warcraft power leveling available in a specific website. Do not be alarmed when it comes to online football betting because even if you are not that computer AOC Power Leveling literate or techie, these online websites have user-friendly interfaces.A good and thorough Warhammer Gold football betting tutorial will try their best to explain to the user that they have acquired all the information they need before they can start betting. They will also try to answer all the possible questions that the AGE OF CONAN Gold new user might be bothered about. A good tutorial, most importantly, will not give false hopes to the beginners but rather only help them increase their chances in winning.
Thanks fu#ktard! Go troll somewhere else!!!!!
__________________
97 FXSTS
Old 11-03-2009, 08:18 AM
bparsel's Avatar
bparsel bparsel is offline
Hang Around
Bearing or belt issue, the sound varying by the clutch pull means it exagerates itself under load. Having a passenger on the back is going to add some tension to the belt. Adjust the belt first and test ride.
__________________
'95 Road King - 60 thou and counting
Tags
harley, making, motorcycle, noise, passenger, rear, slowing, softail, sound, tire, whild, whining, whinning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
