Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Evo Classic Models
Evo Classic Models All Evo Models
Sponsored by: J&M Motorcycle Audio
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-15-2009, 03:02 PM
87HDFXSTC 87HDFXSTC is offline
Hang Around
Default Engine Oil Leak
First of all, if this is a repost I apologize and a link to a helpful post would be much appreciated.
Anyway, my '87 Softail Custom with the 1340 Evo has a small oil leak coming from the split in the crankcase at the very bottom. It appears that it is leaking towards the front of the crankcase and running down the split in the case to the bottom. I have tightened all bolts that hold the case together and that seemed to help, but what are my options if it continues to leak? This is my first Harley. Do I have to split the case and replace a gasket?
Any help is appreciated, thank you.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-15-2009, 03:55 PM
prodrag1320's Avatar
prodrag1320 prodrag1320 is offline
Prospect
there isnt a gasket,are you sure its not coming from someplace else and running down(stator plug,ft lifter block)? cases are a machine fit and its pretty uncommen for the cases to leak
kirby
vee twin racing
Old 10-16-2009, 09:39 AM
Hang Around
I know it's not from the stator plug, that's too far on the left side to be causing the leak. I'll try to take a picture tonight and post it, but it is coming from up around where the engine mounts to the frame on the front of the bike.
I'm embarrassed to admit this, but it started after the bike took a spill in my garage. No major damage, but the bike was on it's side for a couple minutes so I thought maybe some oil leaked out of the breather or something and just worked it's way down to the bottom of the crankcase. That was a few weeks ago and I'm still getting a small puddle so I think I have a constant leak.
Old 10-16-2009, 11:17 AM
t150vej's Avatar
t150vej t150vej is offline
Location: NC and across the Mississippi every opportunity
The thru bolt that holds the cases together, just under the mounting boss can leak from either end - again, not common. And it's very difficult to spot a leak on a silver case, especially. Clean under there best you can and spray with cheap powder type deodorant and it'll show up real well.
If it turns out to be leaking from that bolt on either or both ends, I can give you a fairly easy and permanant fix.
Old 10-16-2009, 01:35 PM
Dr.Hess Dr.Hess is offline
So, Rufus, you're suggesting rolling her in flour and looking for the wet spot?
__________________
Dr.Hess
1986 FLHT: S&S carb, Andrews EV1
1987 XLH 883 Hugger (Wife's): MegaSquirt Fuel Injection
www.drhess.net
Old 10-16-2009, 02:30 PM
t150vej's Avatar
Quote:
Well, something like that... ultra violet lamps, dye, magic wands and such are expensive... and I'm big on what works And repeating what I've said of myself many times; "poor man got poor ways"
Old 10-16-2009, 02:47 PM
sqdealgeorge sqdealgeorge is online now
I did several shovelheads with leaks like this Yes Rufus I put the bikes on their side gently you know Took a toothbrush (not my personal one ) Brakeclean or something like that circa 1974 cleaned it real good than put 2 part epoxy on the wound No leaks reappeared for several years at least till I moved away I think that cleaning fluid was something called Trichlorethane 111 (spelling ? ) That stuff was so toxic I put a gas tank/fenders painted with Emron into a basket at work and lowered the basket into the tank just to the vapor line and within 3 seconds the paint was gone ! Oh the good old days !! It's hard to get that stuff anymore Thank God
Old 10-16-2009, 02:58 PM
t150vej's Avatar
Quote:
You call tell guys with lots of money - 2 toothbrushes... must be nice.
Yeah, I tried to buy some stuff at the parts store couple years ago (can't remember now what it was) and they didn't have it. I tried to leave and he pleaded that I let him call around, insisting he used to stock it. After 20 minutes of him on the phone to everybody he knew and with a straight face he said; "I reckon somebody in California sprayed it on a rat and it died - can't get it anymore"
Old 10-16-2009, 03:50 PM
Rufus I found some in another old tool bag The lable says Trichloroethylene (TCE) What a smell !!!!
Old 10-16-2009, 05:05 PM
Dan89FLSTC Dan89FLSTC is offline
Prospect
Trich is very nasty stuff, in the old days we used to use it a a de-greaser on jet engine parts, we lowered the parts down into a tank that had a hot solution at the bottom, the parts were suspended above in the vapor. Safety and environmental laws finally put an end to that stuff, and forced the industry to come up with non toxic de-greasers.
Tags
1340, 1987, bolts, bottom, case, common, engine, evo, evolution, harley, leak, leaking, leaks, motorcycle, oil, vtwin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
